DA w/ b16 problem!!
Old Jul 8, 2008 | 01:33 PM
efnoobie's Avatar
Default DA w/ b16 problem!!
I have da w/ b16 i just swap im not a pro on swapping cars but.. i did a pretty good job.. no check engine light nothing at all. Stock headers. stock intake. stock pipping everything stock except for the suspension. but my problem is.. wen im on the freeway goin 75 my RPM is on high 5000k. is that normal? My idle is 1500k i know its idling high.. thats one reason i think.. but seems like the engine is strugling. I tried to speed up pass 85 to 90 but seems like my rpm jumps faster... i know its a noob question but feels weird... i have ckeck my timing yet or the belt. Any suggestion? vtec kicks at 4700. thanks..
Old Jul 8, 2008 | 01:57 PM
Papa Joe's's Avatar
Default Re: DA w/ b16 problem!! (efnoobie)
What tranny are you using? could it be that your clutch is slipping! Then with your idle first check the throttle cable for being too tight if not then adjust your idle screw on the intake manifold by the throttle body Good luck
Old Jul 8, 2008 | 10:17 PM
efnoobie's Avatar
Default Re: DA w/ b16 problem!! (Papa Joe's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Papa Joe’s &raquo;</TD></TR><TR><TD CLASS="quote">What tranny are you using? could it be that your clutch is slipping! Then with your idle first check the throttle cable for being too tight if not then adjust your idle screw on the intake manifold by the throttle body Good luck </TD></TR></TABLE>
I have a s1 tranny.. clutch is good lots of meat left.. but i didnt open the tranny while the motor was out..havent really adjust the screw on the IM. ill adjust right now..anymore suggestions.
Old Jul 9, 2008 | 01:26 AM
efnoobie's Avatar
oh i dont know why i have two o2 sensor..
Old Jul 13, 2008 | 05:45 PM
efnoobie's Avatar
ok any help. oh just another question i have 2 o2 sensor? whats the other one for.. i mean thre both almost together..
Old Jul 13, 2008 | 09:49 PM
ozzbirddog's Avatar
did you just do the swap? what engine did you have.... (b18a) ? VTEC engines have a second o2 which needs to be wired to your ECU along with a few other vtec related parts if you haven't already
Old Jul 14, 2008 | 01:52 AM
efnoobie's Avatar
Default Re: DA w/ b16 problem!! (ozzbirddog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozzbirddog &raquo;</TD></TR><TR><TD CLASS="quote">did you just do the swap? what engine did you have.... (b18a) ? VTEC engines have a second o2 which needs to be wired to your ECU along with a few other vtec related parts if you haven't already </TD></TR></TABLE>
Yup i wired that all upp second o2 sensor. knock sensor, vtec, ground.. but the thing is i dont feel no power at high end..im at 75mph goin to 85mph.. feels like its strugling.. rpm is at 5000k which is bad if i cruise around 85mph right? i mean supposed to be around 3k to 4k right?.. i use to have a 92 GSR it feels nothing like it.. i have stock piping.. stock headers could that be it?
MastaFlyMason
May 5, 2013 07:24 AM
EKhatch914
Apr 9, 2009 08:43 PM
cbabyby
11
Apr 11, 2007 07:19 PM
shinobijesus
Mar 13, 2005 04:54 PM
demdem
Feb 26, 2005 11:51 AM
