Compression Test #'s
Old Sep 13, 2003 | 09:10 AM
  #26
89civic1.8T's Avatar
Default Re: (VTECorona)
I just tested my GF's 98 GSR with 83K
I did it with the trottle closed and got 180 on all 4. That's almost 100 psi low/cyl?!! I will try it with the throttle open and see what I get.
Just retested with throttle. Only made the readings go up about 5 psi. I then added a little oil and the readings went up to 210 all the way across.
Modified by 89civic1.8T at 6:39 PM 9/13/2003
Old Sep 13, 2003 | 10:15 AM
  #27
Blk95GSR's Avatar
Default Re: (89civic1.8T)
i got ~215 on all 4 on my 90k 95 GSR.
Old Sep 13, 2003 | 02:48 PM
  #28
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civic1.8T &raquo;</TD></TR><TR><TD CLASS="quote">I just tested my GF's 98 GSR with 83K
Modified by 89civic1.8T at 6:39 PM 9/13/2003</TD></TR></TABLE>
My 250 246 245 245 test was with WOT. You should still get the same result but it'll probably take more cranks to get it to max psi
Old Sep 13, 2003 | 02:50 PM
  #29
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
You are supposed to do it at WOT. Pull your ECU fuse, then test it at WOT. It should give a reading after about 5 cranks.
Old Sep 13, 2003 | 10:35 PM
  #30
T4eg's Avatar
Default Re: Compression Test #'s (integra707)
lookin good
Old Sep 15, 2003 | 02:14 PM
  #31
GSR44's Avatar
would the need for a valve adjustment result in lower than normal compression #'s?
Old Sep 15, 2003 | 02:26 PM
  #32
J337_UNIT's Avatar
Default Re: (GSR44)
i dont think so
Old Sep 15, 2003 | 02:31 PM
  #33
VTECorona's Avatar
Default Re: (GSR44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR44 &raquo;</TD></TR><TR><TD CLASS="quote">would the need for a valve adjustment result in lower than normal compression #'s?</TD></TR></TABLE>
Yes. Valves that are not to spec are not creating the seal which they should be which would result in lower compression.
DAprojectTuRtle
May 1, 2010 02:03 PM
Boostin_GSR
May 23, 2007 01:12 PM
B18 CYA
Jun 9, 2004 12:44 PM
speedymon
Jan 10, 2003 08:02 AM
