compression test results... seems bad?
Old Jun 8, 2004 | 04:04 PM
B18 CYA's Avatar
Default compression test results... seems bad?
the numbers on the right are my results with wide open throttle...
cyl 1 - 150 cyl 1 - 160
cyl 2 - 135 cyl 2 - 140
cyl 3 - 130 cyl 3 - 135
cyl 4 - 140 cyl 4 - 145
motor was rebuilt 1100 km's ago... je 9:1 pistons .... my turbo setup is basically all in except for my intercooler piping ... are these bad compression results?
btw its a 97 gsr
Modified by c2nap at 1:18 AM 6/9/2004
Old Jun 8, 2004 | 04:20 PM
94gsr4dr's Avatar
Default Re: compression test results... seems bad? (c2nap)
seems quite low, how did you perform the compression test?
Old Jun 8, 2004 | 04:22 PM
Jared's Avatar
compression tests should be done with the engine warm and throttle wide open, how was this one done? btw, if it was done properly, cyl #3 is fucked, and 2,4 dont look too good either.
Old Jun 8, 2004 | 04:38 PM
b18bturbo's Avatar
those are quite low for built engine of that nature. If done properly you should be inthe 170-180 region
Old Jun 8, 2004 | 04:44 PM
USDM 4G VTEC's Avatar
i cant remember but i think u cant have no more than 10% variation from ur high compression #
on this case the compresssion numbers have to be withing 16psi from ea other
and the one u have there has a variation of 15%
i say its no goody
do a leakdown test, and find out where the problem lies...
also add about 2 tbspoon of oil into ea cylinder and see if they change.... maybe u got worn rings
Old Jun 8, 2004 | 04:47 PM
sporkcrx's Avatar
Default Re: (USDM 4G VTEC)
With my stock compression (9.1:1) I have 150psi across all 4. This is on a D-series if it makes any difference. Some compression testers read a lil different, but you want the numbers to be similar.
Old Jun 8, 2004 | 05:08 PM
96-EJ6 B18C's Avatar
Default Re: (sporkcrx)
Those seem pretty low and unbalanced
Old Jun 8, 2004 | 05:43 PM
danl's Avatar
Banned
Default Re: (96-EJ6 B18C)
Go out and do some burnouts and flog the **** out of the motor. Hopefully its not too late to get the rings to bite (sounds like it is though). Probably going to have to tear it apart. Double check the piston/wall clearance. Rehone and add new rings. If not, you'll probably end up with an oil eating smoker on your hands.
Oh yeah, no burnouts on a bad tune
Old Jun 8, 2004 | 06:39 PM
B18 CYA's Avatar
i did the test by waiting about an hour til its cool, screw compression tester in and crank it with full throttle .... so what may possibly be wrong? piston rings? btw, it wasnt smoking when i had my original exhaust on and when i didnt put the turbo **** on a few days ago... could it be cause my vacuum lines are not hooked up yet? basically what its doing is building boost but just throwing it out into the atmosphere...getting the intercooler piping done tomorrow
Old Jun 8, 2004 | 07:25 PM
MachAF's Avatar
Default Re: (c2nap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c2nap &raquo;</TD></TR><TR><TD CLASS="quote">i did the test by waiting about an hour til its cool, screw compression tester in and crank it with full throttle .... so what may possibly be wrong? piston rings? btw, it wasnt smoking when i had my original exhaust on and when i didnt put the turbo **** on a few days ago... could it be cause my vacuum lines are not hooked up yet? basically what its doing is building boost but just throwing it out into the atmosphere...getting the intercooler piping done tomorrow </TD></TR></TABLE>
So your saying that you have the turbo on the car, with no vacuum line on the wastegate and the charge pipe is venting to the atomshpere?
I hope thats not that case. If so, your going to over spin your turbo if you already have not.
Old Jun 8, 2004 | 07:54 PM
B18 CYA's Avatar
its only been like that for about 3 days...and i shift at like 2500 rpm all the time and drive real slow ... other end is covered so it doesnt spin as much....
Old Jun 8, 2004 | 08:13 PM
z6's Avatar
z6
id say his motor and turbo are both rite offs...start all over
Old Jun 8, 2004 | 09:12 PM
MachAF's Avatar
Default Re: (c2nap)
i can't figure out why you would get the setup half way installed and go drive around for 3 days.
but yeah more than likely engine and turbo are both toast.
Costly lesson learned.
Old Jun 8, 2004 | 09:21 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
also add about 2 tbspoon of oil into ea cylinder and see if they change.... maybe u got worn rings</TD></TR></TABLE>
Old Jun 9, 2004 | 12:13 PM
B18 CYA's Avatar
i dont understand how installing the turbo with no charge pipes can affect the engine?
Old Jun 9, 2004 | 12:20 PM
B18 CYA's Avatar
could it be a bad turbo seal? how does the turbo seal go bad?
Old Jun 9, 2004 | 12:29 PM
VNTEC's Avatar
B A N N E D
Default Re: (c2nap)
The turbo wouldnt affect engine life, however connecting the turbine with no intercooler piping would blow ur turbine. Most likely your turbine is bad now, it allows the turbine to overrev basically.
Old Jun 9, 2004 | 12:34 PM
z6's Avatar
z6
throw it all away...lol
Old Jun 9, 2004 | 12:44 PM
B18 CYA's Avatar
wouldn't my turbo burn oil if the turbo was bad? when i let off the throttle / decellerate , blue smoke comes out of my exhaust ... and stfu z6
umair
Dec 7, 2009 10:37 AM
MrMug3n
Jul 14, 2008 04:02 AM
97grnrs
Jul 22, 2006 07:52 PM
dirtySOHC's
27
Jun 11, 2002 05:38 PM
