Codes
Old Jun 8, 2006 | 02:58 PM
  #26
jdm_bones's Avatar
Default Re: Codes (jdm_bones)
It can be a broken injector, or bad O rings...
Old Jun 8, 2006 | 03:01 PM
  #27
Seth94GSR's Avatar
I don't have it jacked up or on a lift** just yet, I'll have to wait and do that tomorrow when I go up to Honda.
Old Jun 8, 2006 | 03:17 PM
  #28
jdm_bones's Avatar
Default Re: Codes (Seth94GSR)
Cool then keep me posted, I don't think you need a jack or lift to figure this out...IMO!
Old Jun 8, 2006 | 03:37 PM
  #29
Seth94GSR's Avatar
Aiite, I will..and hopefully it will be fixed tomorrow...Thanks for the help and tips to check..Wrote a list down, going to work on it in the morning.
Old Jun 8, 2006 | 03:39 PM
  #30
jdm_bones's Avatar
Cool bro!
Old Jun 8, 2006 | 05:25 PM
  #31
Seth94GSR's Avatar
This blows so damn bad...Its really frustrating me now..
Old Jun 14, 2006 | 09:59 PM
  #32
EG-B20vtec's Avatar
Hey man,
There are several things pertaining to idle control that can affect the engine's tendency to auto-rev.
Try adjusting the Idle adjust screw located at the top of the TB. The correct procedure for this is to pull the plug off of the MAP and adjust slowly a 1/4 turn and wait for a result. Once it appears that the engine has rested from it's auto-revving issues reset ECU and check again.
If that doesn't work you can actually physically change the position that the throttle plate stops at. It's called the the throttle stop. this actaually allows the engine to see more or less air in large volumes. More so than the Idle adjust screw. This however is very sensitive and should be done with care.
BTW I used to work at Auto Obsessions in PC before they closed. I've done some pretty interesting swaps here in PC. I've seen this a hundred times. I work out of my garage now. Hit me up on here if you can't get it and can't live with it.
Here's some of my work.
https://honda-tech.com/zerothread?id=1155463
D-seriousBis
Apr 11, 2013 05:07 PM
kenfu
Sep 16, 2008 04:15 PM
liftdhatch95
Dec 24, 2007 12:17 PM
MIZIKETSK
Jun 15, 2004 06:36 AM
thashadow
Jun 12, 2002 05:00 PM
