code 22
Old Apr 14, 2010 | 06:26 PM
92 CiviC H.B's Avatar
Default code 22
vtec stopped working,knock sensor broke.so i put a new one,but the cel is throwing a 22 code for the vtec pressure sensor which i bypassed,the vtec worked fine,today it just stopped working.. not sure what the problem is..can anyone help
Old Apr 15, 2010 | 11:46 AM
Left_Sock's Avatar
Default Re: code 22
check over your bypass again, one time mine stopped working because the 2 wires didn't have enough contact
Old Apr 15, 2010 | 05:48 PM
Default Re: code 22
i checked that like four time by now and made sure its on there tight. might be a clogged solenoid,taking it off tomorrow to see.
Old Apr 16, 2010 | 01:16 PM
Default Re: code 22
the cel is still on...can anyone help?? i have no idea why the cel is on for the sensor since its bypassed..could it be a clogged gasket on the solenoid
Old Apr 17, 2010 | 03:43 AM
Left_Sock's Avatar
Default Re: code 22
sometime the code light won't reset unless you disconnect the battery and re-connect it, you might have already done this, but its worth a try
Old Apr 17, 2010 | 09:13 AM
Default Re: code 22
I;'ve done that a bunch of times i even unplugged the ECU battery and fuse and still nothing.
Old Apr 18, 2010 | 05:37 PM
Default Re: code 22
Old Apr 18, 2010 | 09:02 PM
a97b18b's Avatar
Default Re: code 22
To the OP i can't really help ya. and just so I don't have to make a new thread.....
I have/had code 45- too rich or too lean. Now it comes and goes.
Current mods are I/H/E. I've had those mods for a while but installed the headers maybe 2 yrs ago and the light first came on maybe a month ago and when I looked in the bay I noticed I had no coolant so i filled it up and the light went out. After it came on the second time i actually checked to see what the code was and it was 45. Like I said it will stay on for a few days then go away....and all of a sudden it will come back on. Right now it's currently not on.
How and what should I do to pin point the problem??
Old Apr 19, 2010 | 08:23 AM
HondaManMike's Avatar
Default Re: code 22
92hatch, how did you "bypass" the pressure switch? i assume you just grounded the signal wire? if so its still going to throw an intermittent code as it looks for a ground resistance variation at certain points. why did you bypass this?
Old Apr 19, 2010 | 08:25 AM
Default Re: code 22
aslo, have you checked your oil? the wrong weight or too low oil will not allow vtec to engage
Old Apr 19, 2010 | 12:59 PM
Default Re: code 22
the sensor broke so i bypassed it. https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/vtec-oil-pressure-switch-bypass-really-simple-1693528/ ...that's how it was done. its currently on 10-30 motor oil and has enough oil. vtec did work and just stopped one morning. also the solenoid is not clogged because i just put a new gasket on there and took it off to check it.car only goes to 7.5rpms.
Old Apr 19, 2010 | 04:55 PM
Default Re: code 22
Old Apr 19, 2010 | 08:10 PM
Default Re: code 22
hmm, double check your wiring at the ecu. i wish i could help you further but i feel like there is missing info
Old Apr 20, 2010 | 02:36 PM
Default Re: code 22
i checked and its good. i put my friend p28 chipped ecu.the cel is not there anymore but it does not engage vtec. the ecu is chipped and tuned for a ls/vtec fully built. not sure why my vtec wont work,I'm clueless. maybe vtec solenoid
PnoyJeff
Apr 29, 2008 02:00 PM
integracivic94
Aug 22, 2004 08:42 AM
S2KILLA
Sep 17, 2003 05:56 PM
DBallz
Aug 29, 2003 05:56 PM
Civic2Fast
Feb 11, 2003 07:19 PM
