clutch proble,s
clutch problems
I have a del sol with a b18c swap, the engine and transmission now have about 50k on them. today I get in my car and I can't get it into gear and the clutch feals flat. I turn off the car and turn it back on and I can finally get it into gear but the clutch only works when I puch it to the floor. I filled the hydrolic fluid for the clutch but 8 hours later it does the same thing. However I cannot see anything leaking. What should I do?
[Modified by delsolrob, 9:22 AM 2/28/2003]
Re: clutch problems (delsolrob)
Did you bleed the clutch enough? Air in the lines? Are you losing clutch fluid? But you just can't see it leaking out anywhere? Look at the carpeting behind the clutch pedal. When the MC leaks thru the rod seal, it soaks into the matting underneath the carpet & never drips on the ground.
Is the fluid gone again? Check both the master and slave cylinders...master is like he says on the firewall and usually leaks into the cabin, slave is on the front of the tranny. Check both of them for leaks, thats usually where the problem lies.
Slow Egg
11
06-26-2017 11:25 PM
richardman
02-22-2010 07:21 PM
