clutch pedal is stuck on the floor?
Old 01-16-2004, 10:37 PM
Slow Egg's Avatar
Default clutch pedal is stuck on the floor?
ok,
tonight i got in my car drove around for 5 mins and i parked, and when i was about to leave i noticed the clutch pedal was on the floor. Wouldnt pop back up, only if i pulled it with my hand and it would stay up but with a single touch it would fall back down,couldnt get the car into gear either. Latley when droven it felt the clutch pedal was soft,and went down lower and stayed lower than usual.A few days ago my clutch fluid was full, and tonight when it was on the floor it was empty.So i filled it all the way up with dot 3 and it would still stick to the floor and not come back up. what should i do?
Old 01-16-2004, 10:38 PM
blackhatchy's Avatar
Default Re: clutch pedal is stuck on the floor? (egnj)
sounds like you need a new clutch.
Old 01-16-2004, 10:50 PM
SiR HatchAlot's Avatar
you need to bleed the air out of the clutch slave . there must be air bubbles in the line. same thing happen to me when i did my swap. also check for leaks while your there too.
if that doesnt do anything. next thing id do, is change the clutch.
Old 01-16-2004, 10:51 PM
Evil_Wizard's Avatar
Default Re: clutch pedal is stuck on the floor? (blackhatchy)
Check for leaks. Sounds like the clutch master cylinder may have a busted seal or busted hose. After you check all the thyen try bleeding the clutch.
Old 01-16-2004, 11:29 PM
SuperSteve737's Avatar
same thing happened to me. check for leaks and bleed the line. HTH
-Steve
Old 01-17-2004, 12:19 AM
Slow Egg's Avatar
Default Re: (slo_dx)
bump for helppp please
Old 01-17-2004, 01:49 AM
CheEsEsTeAk168's Avatar
Default Re: (egnj)
pump that **** 100 times, it worked for me just keep pushing down 'n pulling up
Old 01-17-2004, 02:15 AM
whoDAT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slo_dx &raquo;</TD></TR><TR><TD CLASS="quote">check for leaks and bleed the line.
Old 01-17-2004, 02:19 AM
SuicideSlide's Avatar
Default Re: (whoDAT)
bleed the line then tell us what happened... This just happened to me... so bleed it...pretty sure this is all that is causing it..
drew
Old 01-17-2004, 05:10 AM
Red CiViC Hatch's Avatar
Default Re: (Tur*bLu)
bleeding may not work....there is a breech in the line somewhere....find it just look around the master and slave cylinder for a leak or look to see if the metal is saturated in oil...on the slave cylinder, move the rubber boot off of it there will be a ball in a clip, squeeze that rubber boot that is right before the ball, if it is filled with oil a new slave cylinder is needed
Old 01-17-2004, 06:55 AM
951's Avatar
Default Re: (Red CiViC Hatch)
im guessing slave cylinder, you probably dont *need* the whole kit, but its not a bad idea
Old 06-26-2017, 11:25 PM
Mil Mercs's Avatar
i know this is old thread. but hope this will help others who experience the same issue. i had this same kind of problem yesterday.
firstly i thought my clutch oil is empty. stuck in the middle of the road at night, i walked to the nearby gas station to buy a bottle of dot3 oil. i refill the oil and keep pumping until the refill bottle almost empty and the clutch pedal is still stick on the floor. later get a tow truck sent to workshop. the mechanic told me that one of 2 bolts that holds the cylinder slave is gone and the cylinder assembly already bent. no idea what drove this thing happened. the oil i just filled in were flushed out from that area. he just tightened it back and get new bolt. it's not about the clutch plate, at least in my case. luckily the mechanic can help me save my money.
tercelrcr
02-02-2013 06:25 AM
93SiHB
10-02-2005 10:00 AM
SPOOLINmatt
03-14-2005 01:04 PM
Superdragr45
01-26-2004 08:17 PM
migs
11-28-2002 07:22 AM
Quick Reply: clutch pedal is stuck on the floor?
