Check Engine Light Code!!!!!!!!
Old Dec 1, 2005 | 07:50 PM
Del Sol on Steroids's Avatar
Default Check Engine Light Code!!!!!!!!
I'm getting three long flashes on a '0 B18C, does any one know what is the code, or where on-line can I find out?
Old Dec 1, 2005 | 07:54 PM
.water's Avatar
Default Re: Check Engine Light Code!!!!!!!! (Del Sol on Steroids)
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
65 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
can i get my 1% back helping this guy?? ROFL
Old Dec 1, 2005 | 07:56 PM
PrinceAli132's Avatar
Default Re: Check Engine Light Code!!!!!!!! (zzzkangzzz)
zzzkangzzz got them right.
Here's a link that you can save so you can always refer to it.
http://www.team-integra.net/se...ID=34
Ali
14baldo66
May 3, 2021 05:50 PM
lblingldawg
Apr 27, 2006 03:10 PM
Downz
Apr 24, 2006 08:55 AM
2dark2bslow
Jun 2, 2004 06:33 PM
skimb37
Aug 26, 2003 04:11 PM
