EK9
Old Apr 27, 2006 | 01:24 PM
lblingldawg's Avatar
Default EK9
I was wondering if someone can help me. I gotta p73 comp type r engine. The check engine light is on. i was wondering if someone can help me jump it and where can i get a list of the codes with the problems? Thanx
Old Apr 27, 2006 | 01:26 PM
b00sted_hatch's Avatar
Little Hercules
Default Re: EK9 (lblingldawg)
here are all the codes
ECU codes:
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
there you go mang!!
Old Apr 27, 2006 | 01:30 PM
yo thanx alot man. DO u know how to jump it? To check which code it throws out?
Old Apr 27, 2006 | 01:38 PM
Little Hercules
Default Re: EK9 (neo_)
your gonna have to let the SEARCH button be your best friend, he works magic!
as for you question, you have to get it on a diognostic machine to see what code you are throwing..what is your R doing?
Old Apr 27, 2006 | 01:59 PM
Eva01's Avatar
Default Re: EK9 (b00sted_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted_hatch &raquo;</TD></TR><TR><TD CLASS="quote">your gonna have to let the SEARCH button be your best friend, he works magic!
as for you question, you have to get it on a diognostic machine to see what code you are throwing..what is your R doing?</TD></TR></TABLE>
J00 dun need a machine, all j00 needs is a paperclip to read the code mang.
Old Apr 27, 2006 | 02:03 PM
Little Hercules
Default Re: EK9 (Eva01)
how the f*** do you do that??
Old Apr 27, 2006 | 02:16 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">Why don't people ever listen?</TD></TR></TABLE>
Because they are lazy.
Here, let me help out
Start here:
http://www.c-speedracing.com/faq/03.php
Modified by Mugen Mike at 5:32 PM 4/27/2006
Old Apr 27, 2006 | 02:21 PM
RTW DC2R's Avatar
jump that ****!
Old Apr 27, 2006 | 03:10 PM
BlkTypeRR's Avatar
^^^dude, you got like 3 feet of air that time^^^^
14baldo66
May 3, 2021 05:50 PM
Downz
Apr 24, 2006 08:55 AM
Del Sol on Steroids
Dec 1, 2005 07:56 PM
2dark2bslow
Jun 2, 2004 06:33 PM
skimb37
Aug 26, 2003 04:11 PM
