CEL directory?
Old Jun 2, 2004 | 06:06 PM
2dark2bslow's Avatar
Default CEL directory?
is there a digital directory anywhere on the net, tried searching HT but came up with 987 results
Old Jun 2, 2004 | 06:11 PM
BlueR's Avatar
Default Re: CEL directory? (2dark2bslow)
did you try the FAQ stickied up top?
ECU codes:
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
JiggyKooAndy's Avatar
0 ECU
1 Oxygen Content
3 Map Sensor
5 Map Sensor
7 Throttle Angle
8 TDC Position
16 Fuel Injector
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
65 Secondary O-2 Sensor Circuit
67 Catalyst System
edit: damn beat me to it!
Old Jun 2, 2004 | 06:12 PM
BlueR's Avatar
Default Re: CEL directory? (JiggyKooAndy)
too slow...lol
Old Jun 2, 2004 | 06:23 PM
Default Re: CEL directory? (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">did you try the FAQ stickied up top?
come on, no one reads those
i forgot to mention its a p28 though...
edit: found ot same difference...damn speed sensor...if its not something its something else..insert hammer!@
Old Jun 2, 2004 | 06:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2dark2bslow &raquo;</TD></TR><TR><TD CLASS="quote">
...insert hammer!@</TD></TR></TABLE>
14baldo66
May 3, 2021 05:50 PM
lblingldawg
Apr 27, 2006 03:10 PM
Downz
Apr 24, 2006 08:55 AM
Del Sol on Steroids
Dec 1, 2005 07:56 PM
skimb37
Aug 26, 2003 04:11 PM
