Check engine light after vtec??
Old Nov 3, 2004 | 08:31 AM
grlstockb18c1's Avatar
Default Check engine light after vtec??
Hey guys I was wondering if you could help me....when I'm driving and I go past 5500RPM, theres sort of a tone change in my exhaust then the check engine light comes on? But when I turn my car off and restart it, the check engine light goes away? Why is this, is this something I shouldn't worry about? I've been told its electrical, it could be something with my sensors...
Thank you!
Old Nov 3, 2004 | 08:35 AM
AlxSiR7's Avatar
Default Re: Check engine light after vtec?? (grlstockb18c1)
um.. the tone change would be your secondaries (assuming you have vtec).. & check engine light might be a faulty o2 sensor.
Old Nov 3, 2004 | 09:00 AM
JimBlake's Avatar
Why don't you read the trouble code? It's stored by the ECU, so the light doesn't have to be on for you to read the code. Read the sticky thread about ECU codes...
Old Nov 3, 2004 | 11:54 AM
Default Re: Check engine light after vtec?? (AlxSiR7)
You idiot...I know its not secondary vtec. Sorry but I can tell the difference and its NOT any vtec at all, sorry....
Old Nov 3, 2004 | 12:20 PM
greaseball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grlstockb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">You idiot...I know its not secondary vtec. Sorry but I can tell the difference and its NOT any vtec at all, sorry....</TD></TR></TABLE>
looking for help and insulting people don't usually go well together. try checking your oil level. if that's good, maybe your o2 sensor. it's really hard to tell without knowing the code.
Old Nov 3, 2004 | 01:15 PM
AlxSiR7's Avatar
wtf is your problem? i was trying to help. damn.. why even post? and i'm the idiot? wtf is secondary vtec?? it's just the butterflies opening in the manifold.. no 2nd vtec.. don't get your panties in a bunch..
Old Nov 3, 2004 | 01:34 PM
PlastikOwl
Guest
Posts: n/a
check your oil.
aznballer's Avatar
the sound is pinging from low oil most likey
Old Nov 3, 2004 | 02:25 PM
Rory Breaker's Avatar
VTEC solenoid. Check the code, I bet its 21.
Try unplugging the connector and making sure its clean.
Old Nov 3, 2004 | 05:18 PM
Default Re: Check engine light after vtec?? (newgsrdriver)
I just wanted to say thank you to the guys who helped me. I really appricate the advice instead of insults. Thanks again...I have a funny feeling that it has to do with my oil, b/c I think my oils low
Old Nov 3, 2004 | 05:19 PM
Youll notice VTEC engages late if your oil is low. Later, later, later, then not at all. You also will see a decreased revlimit.
Your oil light should come on too if its THAT low. The problem youre describing is common with a vtec solenoid issue however.
Old Nov 3, 2004 | 07:07 PM
Masak0's Avatar
It could be the map sensor but im not sure. That is what was wrong with my car after a new engine.
T"u"Rtle
20
Feb 14, 2006 10:17 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
snoop_005
Jan 3, 2004 11:45 PM
inzaneN1
Dec 3, 2003 01:34 AM
boosted spoon
Jul 23, 2002 12:08 PM
