Car stutters while driving
Old Jan 13, 2003 | 02:05 PM
Revline's Avatar
Default Car stutters while driving
I have a 95 LS integra. It keeps stuttering and misfiring when i drive it. While driving it boggles and then shoots off, sometimes it won't even go faster than 40MPH. What could the problem be? I have already changed the distributor to a brand new one. I changed the fuel pump and fuel filter. I also have an S-AFC. The problem still persist. I have an AEM fuel fuel rail and regulator on the car which is getting 35psi right now but it still boggles. I'm happy for any suggestions which might lead up to getting this car fixed. Thank you.
[Modified by Revline, 11:07 PM 1/14/2003]
Old Jan 13, 2003 | 02:09 PM
tegasaurus's Avatar
Default Re: Car stutters while driving (Revline)
spark plugs or wires... if not, have you injested water into your motor?
Old Jan 13, 2003 | 02:54 PM
gsrvx's Avatar
New User
Default Re: Car stutters while driving (tegasaurus)
perhaps failing ignition coil or igniter
Old Jan 13, 2003 | 03:15 PM
Eva01's Avatar
Try changing the plugs next.
Old Jan 13, 2003 | 04:06 PM
Revline's Avatar
plugs and wires I have also changed.
Old Jan 13, 2003 | 04:07 PM
Revline's Avatar
Default Re: Car stutters while driving (RK)
the distributor, ignitor and coil are brand new.
Old Jan 13, 2003 | 04:08 PM
Revline's Avatar
I really don't know if i have...but trhis has been going on for a month now.
Old Jan 13, 2003 | 04:56 PM
IntEGNYC's Avatar
That kind of plugs are you using?
My ex-mechanic slapped in bosch plugs that werent made for my car and it shudderred till i pulled them out.
did it shudder before you swapped the plugs out?
Old Jan 13, 2003 | 05:44 PM
LODOSS's Avatar
Default Re: Car stutters while driving (IntEGNYC)
i would say most liekly the wires but if you did not have proper gapping on your plugs it is also possible.
Old Jan 14, 2003 | 03:16 AM
Revline's Avatar
I have regular NGK plugs in my car and yes it Shuddered when I had the old plugs in.
Old Jan 14, 2003 | 05:40 AM
b19coupe's Avatar
You may have contaminated fuel.
Old Jan 14, 2003 | 06:23 AM
ClVlCGS-r's Avatar
I say plugs and wires
syvpunk
Jul 29, 2010 04:10 AM
NL826
15
Jan 23, 2010 12:22 PM
Mr. V
Classic Hondas
Jan 8, 2010 07:27 AM
blackeg
39
Mar 10, 2004 07:17 AM
Tij
Sep 2, 2002 04:49 PM
