no fuel or spark after tune up
Old 07-28-2010, 04:57 PM
syvpunk's Avatar
Default no fuel or spark after tune up
i was working on my car and did a tune up. plugs wires cap and rotor. also changed the fuel filter. now there is no fuel going to the rail, i did put new washes on. and now there is no spark at the plugs... any suggestions.
Old 07-28-2010, 05:19 PM
delsolproblems's Avatar
Default Re: no fuel or spark after tune up
Check your relays, fuses and grounds.
Old 07-28-2010, 07:41 PM
skuded's Avatar
really man? maybe you should just call a tow truck
Old 07-28-2010, 07:56 PM
syvpunk's Avatar
wow really. i know this is a simple question but i have never run into this while working on cars. no need to flame me on it.
all relays are good. everything new. going to test the ICM. anyone know the voltage specs?
Old 07-28-2010, 08:14 PM
skuded's Avatar
your saying that you changed the fuel filter which only goes on one way and you have no fuel after changing it, and also your saying you changed the distributor cap and rotor which also only go on one way and your saying that after doing both of these that neither of them are working properly. did you let the pump prime a few times after changing the fuel filter, and just for the hell of it try banging on the lower left hand side of the dash while cranking it to just verify the pgmfi relay working properly
Old 07-28-2010, 08:57 PM
Former User's Avatar
You should mention the year, trim, and engine.
Check the ground on thermostat housing and the three main relay fuses.
Old 07-28-2010, 10:37 PM
syvpunk's Avatar
yes i did all of these things. i have done many a tune ups on honda/acura/ mine being a 99 civic lx 1.6.
finally got fuel to the rail. now just done have spark. i have checked all relays and grounds. turns out the coil is out. checked the specks and have no voltage reading from this at all. i checked all the ohms and nothing. sorry been a long day. thanks for all the assistance.
Old 07-28-2010, 10:48 PM
Linked's Avatar
qs on why coil went out
if by any chance you were cranking the engine with the spark plug wires out of the dizzy or engine, you can burn the coil out that way
Old 07-29-2010, 04:10 AM
skuded's Avatar
dont just replace the coil, go out and buy a new or re-built distributor, its worth it for the hassle if your coil went bad chances are your icm went bad or will go bad as well, if you get a rebuilt dist at anywhere like orielys or autozone its about 250$ but it has a lifetime warranty
csckwade
12-28-2012 11:01 AM
92integraVTECgsr
10-20-2010 05:44 PM
Understeer
11-19-2005 07:09 PM
Krayzielix
02-02-2003 04:12 PM
Tij
09-02-2002 04:49 PM
Quick Reply: no fuel or spark after tune up
