Brake light on?
Old Sep 27, 2005 | 11:51 AM
...rohit's Avatar
Default Brake light on?
Its been happening for the past few weeks. When i go to school in the morning the brake light stays on for some odd reason. It eventually goes away after about 4-5 miles of driving. does anyone know why it would be doing this? the brake is not engaged at all.
Old Sep 27, 2005 | 12:44 PM
laezpnai's Avatar
Default Re: Brake light on? (desipiE)
check your brake fluid.. also sometimes the ebrake handle engage thing or something sticks
i had this problem too and it just went away on its own..
Old Sep 27, 2005 | 12:46 PM
snipertoeteg's Avatar
It's been happenen to me too i was just going to make a post about this.Thank for the post haha.
Old Sep 27, 2005 | 12:52 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Brake light on? (laezpnai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laezpnai &raquo;</TD></TR><TR><TD CLASS="quote">check your brake fluid.. also sometimes the ebrake handle engage thing or something sticks</TD></TR></TABLE>
Check brake fluid level first. Then check the E-brake, most of the time that never goes bad.
Old Sep 27, 2005 | 05:52 PM
Sam92Teg's Avatar
Default Re: Brake light on? (shamoo)
There is also a switch on your brake pedal arm that has a contact point made of plastic, at least on 2nd gen integra's it is. Make sure that switch and contact point are meeting each other properly. If the plastic contact point gets wedged to the side or broken into pieces, it could cause your brake light to stay on. My plastic piece broke and my brake lights stayed on, so I used a plastic panel fastener and stuck it in its place as a temp fix, two years later its still working fine.
Opps, I just figured out you meant your dash brake light, not your tail lights, dangit.
Old Sep 28, 2005 | 09:10 AM
...rohit's Avatar
Default Re: Brake light on? (Sam92Teg)
thanks anyway man
Blk_Lude98
Oct 20, 2006 07:27 AM
grandmasterflash
Dec 28, 2005 05:55 AM
peshte
Aug 26, 2005 03:13 AM
ham_yorkwind
Apr 10, 2005 07:43 PM
kolohekine
10
Jan 27, 2005 04:44 PM
