bad idle
Old Jun 18, 2008 | 12:54 PM
dizzyroc88's Avatar
Default bad idle
symptoms are:
cold start it idles at 3k
drops to 2k when warm
sometimes has a fast idle between 900 and 2500. it will cycle through this a couple jumps and settle out somewhere around 2300
i take off the tps and nothing happens except the CEL comes on. i take off the IACV CEL comes on and idles stays jumping
any thoughts?
Old Jun 18, 2008 | 11:27 PM
gtec8285's Avatar
Default Re: bad idle (dizzyroc88)
bump for this guy!
i have the same problem i mean exactly the same problem as in the idle would be the same from 3k cold and warm bout 1.5k
Old Jun 19, 2008 | 01:01 PM
dizzyroc88's Avatar
Default Re: bad idle (gtec8285)
well i fixed the idle today. i first replaced the iacv with a spare i had .. that didnt fix it.. so then i went on to replace the tb with an extra i had also with a new tps. problem solved. idles back down at about 800. BUT now im smoking.
when i got the car it had an oil leak around the vtec solenoid but no smoke. could it be that something got worse inside or its smoking cuz of the tb having sit for a while (which ive never heard of happening)
any suggestions. if i had bent a valve how could i tell
Old Jun 20, 2008 | 09:16 PM
egb16pg's Avatar
when does it smoke?
what color is the smoke?
Old Jun 20, 2008 | 09:30 PM
all-mtr-teg's Avatar
Clean your map sensor and iacv.
Old Jun 20, 2008 | 10:01 PM
dizzyroc88's Avatar
Default Re: bad idle (all-mtr-teg)
smoke is black but not thick like dirty black... the car runs thru gas so i hope im running rich. i did a compression check today and i got 210 210 210 215 and my spark plugs were black az fawwwk. all carbon'd up
as far as when it smokes all the time.. its light but consistent. comes heavy when im in vtec
im gona try going back to the old iacv tomorrow cuz i think the tps was the source of the bad idle.
Modified by dizzyroc88 at 2:13 AM 6/21/2008
Old Jun 20, 2008 | 10:08 PM
dizzyroc88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtec8285 &raquo;</TD></TR><TR><TD CLASS="quote">bump for this guy!
i have the same problem i mean exactly the same problem as in the idle would be the same from 3k cold and warm bout 1.5k </TD></TR></TABLE>
do what i did. freshen up the throttle body or replace entirely with new tps and new gasket go from there.. you got too much air coming in.. if the iacv was your problem the idle would jump all the time.. if its steady look towards your tb for the source
edit*... assuming that all your vaccum lines are skr8 and u got nothing serious wrong like a blown hg
another edit lol* or your could have jumped a tooth . check timing make sure its all peaches and gravy
mikeunreal2
Mar 29, 2006 09:27 PM
kihun_cha
20
Sep 17, 2004 03:18 PM
TheIntegraGuy
Jan 22, 2004 06:48 PM
diLUDEd
Aug 22, 2002 10:08 PM
