Advice on setup
Old Nov 13, 2006 | 05:36 PM
mcgee*'s Avatar
Cigarette Squad
Default Advice on setup
Ok im on a 800$ budget and would like yalls input on rebuilding my engine
Specs:
1997 LS B18B1
What'd id like to do.
GSR Head
Now this is where i need some help, for the block i wanna rebuilt since the engine is getting old so why im taking head off might as well rebuild block.
Now whats a good setup for the block like piston wise or whatever you think is a good idea let me hear it
Im new the bseries so im trying to learn so help meeee
Modified by McGeeTM at 10:32 PM 11/13/2006
Old Nov 13, 2006 | 05:43 PM
Rikter's Avatar
best advice ever.....search function.
-Rik
Old Nov 13, 2006 | 05:45 PM
ckyguy's Avatar
pick one or the other on a $800 budget. You won't do a very good job rebuilding the engine and/or a very good ls/vtec job unless you double your budget
Old Nov 13, 2006 | 06:03 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (ckyguy)
not like a fully built setup just something to keep it going..just a little more than oem pistons.
search owns me, not good with searching on something i dont know what to look for
Old Nov 13, 2006 | 06:22 PM
.Smitty.'s Avatar
Default Re: (McGeeTM)
Honestly, save your money man. It's better to build a more expensive setup that you know will be reliable to where you can run it hard and have no worries over building one on a budget of 800. You'll skip out on important parts for the long run. It may run good now, but after a while things will start failing. Save up, or start gathering parts now and when you have the right stuff, then go ahead with the build.
Goodluck again
Brett
Old Nov 13, 2006 | 06:32 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (.Smitty.)
Alright yeah im in no rush right now..i just picked up the car a week ago and has 200k miles and smoking so needs either rings or seals so ill look out thanks tho.
Old Nov 13, 2006 | 07:03 PM
Micha's Avatar
FAILWGN
order a B20 from Hmotoronline. It will be about that much and work in your car.
Old Nov 13, 2006 | 07:09 PM
slow_ls's Avatar
Wow dont break the bank. But seriously, when you've saved more money just have it fully balanced, micro polished crank, shot ping the stock rods, all arp bolts especially the rod bolt cause the ls are ****, and get some gsr or type r piston and of course the usual hone and a golden eagle ls vtec kit, and your set. But if it was me I would also wait and just save and rebuild the head at the same time. Also it will suck with ls tranny; you'll fall out of vtec between shifts.
Old Nov 13, 2006 | 07:10 PM
mcgee*'s Avatar
Cigarette Squad
Default Re: (Blu99teg)
yeah i was thinking that, is the gsr head compatible with the b20? or is the b20 more of a boost engine also i read somewhere it had thin cylinder walls is that as bad as it sounds?
Old Nov 14, 2006 | 07:31 AM
Sam92Teg's Avatar
VTEC heads will mate to the B20 fine, but your better off having your B18B sleeved and bored to 84mm if you want more displacement.
On the cheap, if you must, go with P30 or PR3 pistons with your B18B block because no mods are needed to use your stock rods, and these will give you a nice bump in compression. Use ARP rod bolts as stated earlier and have them resized. Hastings rings are more affordable than OEM by $50 and just as reliable. ACL bearings are reliable bearings if they are within clearance specs and will save another $100 over OEM. But go with an OEM headgasket. Also ARP headstuds are reusable, so those are a good investment. If you have enough money left over, use 96 or newer oil/water pumps. And new VTEC timing belt and tensionor. Good luck. And get a good tune.
Old Nov 14, 2006 | 07:41 AM
neovvl's Avatar
---Engine, LSVTEC and CRVTEC---
https://honda-tech.com/zerothread?id=1119323 – A Few Good Links
https://honda-tech.com/zerothread?id=1082172 – A Few More Good Links
https://honda-tech.com/zerothread?id=1083788 – Break-In Period
https://honda-tech.com/zerothread?id=501372 – Reliability Issues
https://honda-tech.com/zerothread?id=720621 – Quarter Mile Times
https://honda-tech.com/zerothread?id=805408 – Using LS ECU
https://honda-tech.com/zerothread?id=1467903 - B20 NonVtec FAQ - *THANKS DRINTEGRA & BAMBAM*
https://honda-tech.com/zerothread/1767009 - B18C1 vs B16A Head flow chart * THANKS dohcMONSTER*
Also try these:
---Links to Other FAQ’s That You Should Read---
https://honda-tech.com/zerothread?id=766629 – Integra Type R Forum FAQ
https://honda-tech.com/zerothread?id=1171263 – EG+ Forum ECU FAQ
https://honda-tech.com/zerothread?id=878010 – EG+ Forum Swap FAQ
https://honda-tech.com/zerothread?id=637661 – CRX/EF Forum FAQ
https://honda-tech.com/zerothread?id=689805 – Prelude Forum FAQ
https://honda-tech.com/zerothread?id=856655 – NSX Forum FAQ
https://honda-tech.com/zerothread?id=1024174 – Forced Induction Forum FAQ
https://honda-tech.com/zerothread?id=1022836 – Welding/Fabrication Forum FAQ
https://honda-tech.com/zerothread?id=650230 – Hybrid Forum FAQ
https://honda-tech.com/zerothread?id=1188922 – Wheel and Tire Forum FAQ
https://honda-tech.com/zerothread?id=1093464 - How to Photoshop *THANKS STOCK LS*
http://www.diyimports.com/seafoamprint.html - Seafoam How-To *THANKS STOCK LS*
Old Nov 14, 2006 | 07:49 AM
95 integra's Avatar
Default Re: (neovvl)
ls/vtec = complete head, ecu, wiring, ls/vtec kit = $800+
Old Nov 14, 2006 | 09:26 AM
schoedog2323's Avatar
Default Re: (95 integra)
just go with a b20 they can be had for 650 bucks and will give u a complete good running motor
mikeycivic
Feb 28, 2008 05:22 AM
ej6hatchie
Feb 22, 2008 09:45 AM
sluggo
Sep 19, 2007 01:52 AM
seifer
May 19, 2006 09:55 AM
trucdoken
Jan 13, 2005 01:23 PM
