1st and reverse sometimes wont go into gear.
When going into 1st or reverse, usually first, it wont go into gear and I have to let the clutch out a little in order for it pop in. Could it be the shift bushings? or a clutch issue? Need an answer please.
Re: 1st and reverse sometimes wont go into gear.
Hmm I seem to suffer the same issue especially on a cold start, 1st is always a pain in the *** to get into while every other gear shifts like butter lol. My first guess would be bushings but I'm too lazy to check my self.
Check rear motor mount for excessive movement. Also, possibly clutch master cylinder going bad. Look for a leak/wetness by clutch linkage up under dash. How low is your clutch fluid?
jwshilli
07-14-2009 03:02 PM
