How to: install JDM access visors
Old 08-08-2003, 08:44 AM
barto's Avatar
Default How to: install JDM access visors
when i tried looking for help here all i got was "i heard its hard", "use the clips" and "OMG JDM visors just get ones the attach with a sticker for $20" so i went ahead and installed them my self. the first side took like an hour, the second side only took like 20 min once i figured it out.
1. start off by attaching the screw ones. they go on the top by the pillar, and one close to the rear view mirror.you have to pull back the rubber on both the side and the top. there are already holes for the screws. put the bracket underneath the window sil and screw it in from the top. i guess you are supposed to use the washers for the screw bracket but i didnt, ill get to that in a minute.
2.hold the visors up to the window so you can see where you will need to place the other clips. you will need to remove that **** thing that is on towards the front middle, that is where one of the brackets will need to be located. you can get an idea of how the brackets go in when you take it out.
3. push the rubber stripping back in. i had to use a flat head screw driver to push the little rubber lip in all the way. when i pushed it all back in it didnt look as smooth or clean as it did before i installed the visors but just make sure everything is back in and it wont matterwhat it looks like b/c it willbe covered.
4. clip in the visors at each end. one goes in underneath the mirror, the other goes underneath the pillar. i had to unscrew it slightly to make it easier to slip the clip under neath. make sure all the brackets get aligned with the holes. if they are off i took a screw driver and wedged it in the rubber stripping and moved it over to where it needed to be.
5. the last step: put in the gromets. the gromets are pretty much self explanitory. if you have ever taken off your bumper, they are the same ones that are on the grill (96-00 civics, not sure about 92-95) only they are hella small so dont drop them. so put them in all the brackets with the circle holes. the brackets with the oblong holes is where i used the washers. i first used the washer where i was told to, (on the brackets that screw in) but when i tried to put the gromets in the oblong holes it wouldnt stay in so i took the washer and put it underneath the clip (or on the inside if you will) and then put in the gromets and you are done!
6. take some windex or any cleaning solution of your choice and give them a rub down b/c by now you have hella fingerprints on it.
6.2 take it for a drive and feel the JDM wind blocking action
Old 02-20-2004, 08:30 AM
Grip's Avatar
Default Re: How to: install JDM access visors (barto)
hell yea
Old 02-20-2004, 08:56 AM
JDEM1's Avatar
Default Re: How to: install JDM access visors (Grip Driver)
take some pics
Old 02-20-2004, 09:06 AM
white95eg's Avatar
Default Re: How to: install JDM access visors (JDEM1)
i plan on getting these, could you post some pics?
Old 02-20-2004, 11:24 AM
137's Avatar
Default Re: How to: install JDM access visors (white95eg)
ill do an install pictorial later on tonite.
Old 02-20-2004, 12:32 PM
eg360B's Avatar
Were do they sell those. been looking for some?
Old 03-02-2004, 10:16 PM
ryanislikebro's Avatar
Default Re: How to: install JDM access visors (137)
yea i wanna see pix jsut to make sure i do it right.....haha
Old 03-02-2004, 11:09 PM
Soulless's Avatar
Default Re: How to: install JDM access visors (ryanislikebro)
i want some of these...the stick on ones i like cuz of price, i just dont want to have to keep replacing them cuz the get blown off...
Old 06-03-2004, 07:35 PM
ajjohnsonnc1's Avatar
Default Re: How to: install JDM access visors (Soulless)
bump for later
Old 09-28-2004, 03:24 PM
Bao Weezy's Avatar
yo i just picked up a pair of jdm visors and man this **** is ****** pissin me off!!! I need help on how to install them. please reply!!! mucho gracias.
Old 09-28-2004, 03:27 PM
SOHC4life 96's Avatar
Default Re: How to: install JDM access visors (Bao-7)
There is a FAQ thread up on top of the EG+ forum. Look through that, there are many write ups and Im almost positive that there is one about this install and it has pics too.
Here
https://honda-tech.com/zerothread?id=642479
Old 09-28-2004, 03:37 PM
cxSHOE's Avatar
for ek visors but its the same for the eg.
https://honda-tech.com/zerothread?id=632263
Old 09-28-2004, 11:15 PM
JDMish's Avatar
Do the visors just snap in under the weather stripping on the doors? Where can I get a set? how much?
Old 09-28-2004, 11:17 PM
137's Avatar
Default Re: How to: install JDM access visors (JDMish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMish &raquo;</TD></TR><TR><TD CLASS="quote">Do the visors just snap in under the weather stripping on the doors? Where can I get a set? how much?</TD></TR></TABLE>
Do a search for my name in this forum... you will find the diy I just rehosted the pictures.
http://www.icbmotorsport.com has the visors at a good price, they are not just snap on its a bitch to install them and takes patience.
Old 09-28-2004, 11:49 PM
eug_34's Avatar
Yes lets see some pictures. Im looking for a set also... does anyone here know where i can pick up a set for a decent price?
Old 09-29-2004, 01:40 AM
137's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.icbmotorsport.com has the visors at a good price, they are not just snap on its a bitch to install them and takes patience.</TD></TR></TABLE>
Old 09-29-2004, 09:01 AM
ILuvJDMITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDEM1 &raquo;</TD></TR><TR><TD CLASS="quote">take some pics </TD></TR></TABLE>
Old 09-29-2004, 09:39 AM
TallAssFilipino's Avatar
Default Re: How to: install JDM access visors (ILuvJDMITR)
Somebody needs to do one for an EG. I have an EH2 but don't want to put them on that daily car. I'm still looking for a black EH3. I, also, have a couple EH/EG visor sets. On the EH/EG visors, the clips already come pressed/molded on the inner plastic/visor side. And none of the clips (even the end clips) have a hole on them to screw onto the door-window pillar. The visors don't look anything like the one's for the EK's and DC's. At least the ones I have don't. Also, both of my sets are different. My older set of visors are a solid black. My newer set are tinted, but can still see through them. Both say: Honda &gt;PP&lt; on the insides.
Old 05-25-2005, 08:16 PM
gotboostedvr6's Avatar
Old 11-19-2008, 06:38 PM
cool_KID's Avatar
can anyone post pics on how they installed the visors
Old 11-20-2008, 04:11 AM
Koopa Troopa's Avatar
The visors have metal tabs that clamp under the weather stripping on the door... It's self explanatory...
Old 11-20-2008, 08:59 AM
pliskin8's Avatar
Icon6
<br />
<br />
<br />
<br />
<br />
<br />
]<br />
<br />
<br />
just follow the steps, i did mine exactly like the pics and the visors fit perfect
Old 07-03-2011, 12:27 PM
ment2bzer0's Avatar
me likey. thanks.
Old 12-11-2011, 09:21 AM
CaSpAr4Rm916's Avatar
Most of the post i seen is all those black clip that u can just roll window down an clip on, then put the black clip from the outside. how about the real deal clips?, the clip that comes with the OEM visors... Any good post on that?
By the way, nice write up
cherryhatch00
04-01-2008 02:46 AM
Fliplm0de
06-05-2007 03:25 PM
dj_audio
10-21-2006 12:39 PM
Hatchdude
12-26-2004 02:52 PM
jdm_cars
11-18-2003 04:38 AM
Quick Reply: How to: install JDM access visors
