92 Civic SiR with B16A engine - jerks
At a certain speed my car jerks (around 30-40 km/h) and I can feel it the most in the morning. I always warm up my vehicle before driving it. Please help!! Thanks!
Re: Car jerks
you need to tell us about your car, though. 5th generation or 6th generation? Which trim level? Any modifications? Mileage?
Last edited by Former User; 08-01-2014 at 03:39 PM. Reason: Text deleted - knock it off
Re: Car jerks
Lol!
Its a 92 Civic SiR with B16A engine (118K km). Did some tune up (except the fuel filter and PCV's) and timing belt and water pump change recently. Car is stock except for the aftermarket Air filter.
The Grumpiest
Re: Car jerks
Not enough info.
At the very least you need to give vehicle info. When was the last time you did a tuneup?
And be careful who you listen to. There are a lot of people on this forum giving advice that can't even perform basic maintenance on their own vehicle or identify parts of it.
Re: Car jerks
Not enough info.
Re: Car jerks
Re: Car jerks
Actually I forgot went it really started, but probably a month ago... Ohh I remember after I change the Speed Sensor which is a month ago.
Re: Car jerks
There are so many possibilities, I find a video best.. take one, youtube it and post it here?
While you're pressing the gas,
Is it jerking back and forth, or does it just feel like it's cutting out like a rev limiter? (this is often caused by bad plugs, spark plugs, and sometimes the distributor cap having a crack/leak.)
If it's jerking back and forth it's more likely fuel related, so we're talking fuel pump, injectors etc.
Does the car turn to one side when it jerks? try letting go of the steering wheel and check, could be a lose arm at the bottom even.
Re: Car jerks
My eh2 with a b16 had same issue. It was fuel, cleaned my injectors and then found wiring issues with fuel pump. check everything and write down what you've done & when and keep with your Chilton/Haynes, save time researching the same damn thing over & over
Re: 92 Civic SiR with B16A engine - jerks
Sounds most likely like a misfire OP although a video would be extremely helpful. Additionally, if you turn on extra electrical things like lights, AC, windshield wipers, etc, does this get better or worse?
basedmark
16
02-05-2012 08:38 AM
KMSol
10-09-2010 09:01 PM
