How to fix broken speedometer.
Old 03-16-2011, 12:03 PM
xjm92x's Avatar
Default How to fix broken speedometer.
I have a 1994 honda civic and when i drive sometimes the speedometer needle does not move or sometimes it goes to outrageous numbers like i could be going 30 mph n it goes all the way to 60 or even 100 what could be the problem?
Old 03-16-2011, 03:05 PM
CHandshuh97EX's Avatar
Default Re: How to fix broken speedometer.
wiring is messed up
Old 03-16-2011, 05:04 PM
JDyzzle's Avatar
vehicle speed sensor, its located near the rear or the transmission on top one 10mm bolt holds it in
Old 03-16-2011, 06:16 PM
hannslebo's Avatar
I have this same problem...I do not think it is the speed sensor. I have replaced that, and it still does it. Im thinking its in the wiring behind the cluster?? It is a DX chassis/body, but has a EX cluster. The car runs like normal, vtec still kicks. So any more info on this would be greatly appreciated!
THANKS!
Old 03-16-2011, 07:21 PM
ej2b20v's Avatar
clean the plug that goes to the sensor on the tranny. i had the same problem once
Old 03-17-2011, 03:18 AM
russ.shafer's Avatar
do what ej2b20v said .or try a dif cluster if you changed the vss sensor
Old 03-17-2011, 05:19 AM
xjm92x's Avatar
Do i have to take the car apart to get to the plug or just the cluster?
Old 03-17-2011, 09:11 AM
thecruzs2007@yahoo.com's Avatar
just take the bezel off, take the 4 screws and take the cluster out..
Old 03-21-2011, 08:45 PM
ej2b20v's Avatar
its the one that goes form the sensor to a grey plug clean out the grey plug in the inside sometimes it gets coroted
Old 03-21-2011, 09:10 PM
dem0nk1d's Avatar
some times the circuit board goes bad on the rear of the gauge. you'll see this board once you remove the gauge from the cluster housing.
when i bought my car the speedo would randomly work, i changed out the board from a junk yard gauge, and started working right away.
Beto760
09-07-2010 11:00 PM
TeamEK
05-20-2009 08:34 AM
Civicthusiast
02-17-2009 08:30 PM
venom363
05-08-2007 11:48 AM
hip_hop_s0ulchild
03-01-2007 03:41 PM
Quick Reply: How to fix broken speedometer.
