Changed clutch, throwout bearing noise help!
Old 03-21-2011, 08:56 PM
05foresterxt's Avatar
Default Changed clutch, throwout bearing noise help!
I just finished changing the clutch on my 99 Si. I changed the clutch, throwout bearing, and the bearing that goes on the flywheel. All parts are Honda oem parts. Even though all bearing were replaced, I can still hearing the noise from the throwout bearing when I release the clutch pedal. Is this noise normal or could it be something else?
Thanks.
Old 03-21-2011, 09:03 PM
Former User's Avatar
Default Re: Changed clutch, throwout bearing noise help!
Noise when the clutch pedal is release is likely a bad main bearing (input shaft) in the transmission.
Old 03-21-2011, 10:00 PM
Oh man, how bad is that? Should i worry about it? It was hell taking the transmission off and putting it back on, I can't imagine doing it again.
93accordEX
02-02-2010 04:40 AM
Aron Parsons
03-06-2006 09:18 PM
pa2play
07-28-2005 09:42 AM
tegtuner94
05-17-2005 07:20 PM
Quick Reply: Changed clutch, throwout bearing noise help!
