DIY: 92-95 EH/EG/EJ Low fuel sender installation and wiring
Old 03-07-2011, 02:07 PM
tlarimer's Avatar
Default DIY: 92-95 EH/EG/EJ Low fuel sender installation and wiring
Well this will be my first DIY, so bear with me...
This will guide you through installing a JDM/USDM low fuel sender into a USDM 92-95 EH2/3 Civic Hatchback, the installation should be the same for other bodies, but I don't know if the low fuel sender is the same P/N.
What you will need:
USDM low fuel sender P/N 37800-S04-305
1 pin from cluster connector
1 male/1 female pin from standard Honda connector
1 large female pin
RED/GRN stripe wire(parking brake wire from 92-95 civic)
JDM/EDM cluster with low fuel light or modify your USDM cluster
I'm not going to go into detail for removing cluster, back seats and replacing USDM fuel sender with low fuel sender, but they need to be removed and new low fuel sender need to be installed.
You are basically running one wire from Pin A7 at the cluster back to Pin 3 in the fuel sender connector. But I like to try and keep everything nice and clean, so I ran the wire through the blue connector at the top left of the fuse box for a cleaner install.
Well there you have it, if you did it correctly, then your low fuel light should work, if not check all your connections.
You can test the low fuel light by jumping Pin 1 and 3 on the fuel sender connector, turn the key on and low fuel light should come on.
Feedback welcome, but keep in mind this is my first DIY and I can adjust anything you feel lacking or needs more attention.
Special thanks need to go to Deschlong for his help and diagrams.
Thanks,
Tim
Old 03-07-2011, 02:13 PM
votoms888's Avatar
Default Re: DIY: 92-95 EH/EG/EJ Low fuel sender installation and wiring
Nice. Thanks for the post. It'd be nice to know how low the fuel level is.
Old 03-07-2011, 02:19 PM
Black Diamond's Avatar
Nice bro, looks like your pics are messed up though!
Old 03-07-2011, 02:22 PM
tlarimer's Avatar
Fixed
Old 03-09-2011, 02:03 PM
tlarimer's Avatar
Fixed all picture links and added information
Old 03-09-2011, 03:56 PM
Former User's Avatar
Link added to FAQs sticky.
Old 03-09-2011, 04:11 PM
Gunmetal_B20_Hatch's Avatar
coolsies... What clusters had this?
Old 03-09-2011, 04:19 PM
tlarimer's Avatar
Most JDM and EDM clusters, but not all, be cautious. The one I installed is a EDM EG6 VTi cluster.
But you can also modify your USDM cluster, like in this thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bcivic-92-95%5D-usdm-fuel-temp-gauge-question-2862483/
Old 03-26-2011, 10:31 PM
jmaze's Avatar
nice with pics!
Old 03-27-2011, 12:03 AM
ElliotSiR's Avatar
Added to my IE favorites. I'll be doing this once I get an actual cluster rather than my garbage stock one with no tach.
Old 03-27-2011, 01:17 AM
Need_jdm's Avatar
dope!!! ill do this later today
Old 04-13-2011, 08:12 PM
jmaze's Avatar
I finally got around to wiring mine but used the up-shift arrow on my cluster since I have a vx. I jumped it so I know it works just waiting for the tank to get low.
Old 07-10-2011, 02:24 PM
tlarimer's Avatar
Updated, added schematics and diagrams
Old 07-10-2011, 05:53 PM
Resident Gearhead
BryanM.'s Avatar
Great write up and I want your gauge cluster.
Old 07-10-2011, 06:07 PM
tlarimer's Avatar
Thank you, you can usually find them on UK ebay for $100-$125 shipped to the US
Old 07-10-2011, 06:16 PM
Resident Gearhead
BryanM.'s Avatar
Thank you.
Old 08-03-2012, 04:12 AM
Andres-David's Avatar
Wow! thanks for the info, I'm gonna do it in my civic !
Old 11-25-2013, 07:56 PM
SozeHuck's Avatar
Thanks for the sender Part number!
Old 12-26-2013, 11:48 AM
olfirehand's Avatar
Just bought a UKDM cluster for my CRX which has a low fuel light. Do you or anyone else happen to know if the sender you used (part number above) is usable on my car. I have a USDM 1988 CRX SI and I replaced my fuel level and fuel pump last year. Any help would be much appreciated.
Old 12-26-2013, 12:05 PM
95Sedan's Avatar
you could do this with an LED placed somewhere else besides cluster right?
Old 02-19-2018, 09:29 AM
Riptide101's Avatar
Any possibility of reuploading the photos?
Old 02-21-2018, 10:35 AM
Oh look, I can change this
deschlong's Avatar
Photos work for me .... I expect you need the photobucket hotlink fix: (for chrome) https://chrome.google.com/webstore/d...er-info-dialog
LuckyStrike90
04-25-2018 03:10 PM
deschlong
28
06-29-2017 11:24 AM
fungus mungus
93
12-09-2011 07:35 AM
jmaze
10-24-2007 07:31 PM
hatchii
11-04-2002 02:43 PM
Quick Reply: DIY: 92-95 EH/EG/EJ Low fuel sender installation and wiring
