Im stumped. How do you check fuel pressure eg hatch
Old 12-18-2009, 06:43 AM
happyabortion's Avatar
Default Im stumped. How do you check fuel pressure eg hatch
Oki so I have a eg hatch I just dropped a fresh swap in. I also installed a brand new fuel pump in it. It sounds a bit funny when it primes and when I first got it put together it took a minute to get fuel to the fuel rail. I would like to check fuel pressure but I dont know where to hook up a fuel pressure tester to. can someone give me some help? and If you got any ideas on what could be wrong with my car let me know too! Any help would be greatly appreciated!!
Old 12-18-2009, 07:14 AM
Luserkid's Avatar
Default Re: Im stumped. How do you check fuel pressure eg hatch
What fuel pump are you using? Check the voltage going to the pump and make sure its enough to power the pump. For the tester it depends on what type you have but you could pull the return line off and T into that.
Old 12-18-2009, 07:48 AM
CRX T-Si's Avatar
Easiest way is to just get a fuel pressure gauge which is like $30 bux and make sure it comes with the fitting onto the fuel filter.
Old 12-20-2009, 05:32 PM
I had the original one on there and I install a brand new autozone one that seemed to work better but not right. I probably do need to go buy a gauge but im afraid that I'd need some metric fittings which I KNOW the tool i buy locally probably wont have it. But that idea of the return line I believe will work also so i might do that
the only problem with this like I said is I dunno if they'll have mm fittings.
Also I have a b-series aem fuel rail with a guage on it. is there any way I can take that guage off of the rail and stick it on my sohc somewhere? or am I just talking crazy?? lol
Thanks everyone for the help I really appreciate it.
Old 12-20-2009, 06:40 PM
MiG-21 superfan
builthatch's Avatar
since 1998 i've used these - http://www.summitracing.com/parts/BMM-46054/
Old 12-21-2009, 05:18 AM
CRX T-Si's Avatar
x2
That is what I mean, the kit that comes with the fittings and they are metric.
You can take the fuel gauge off your AEM fuel rail however you would still need the fittings onto the fuel filter.
You can get the entire guage or you can get just the gauge adaptor which is like $8.95 + shipping from eBay.
http://cgi.ebay.com/ebaymotors/ws/eB...d=250408498456
Old 12-21-2009, 07:33 AM
1sikegsir6's Avatar
^^^^^ yea wut he said lol
Old 12-21-2009, 10:04 AM
joelmatt89's Avatar
just go to harbor freight their fuel pressure their is ten dollars and I know it comes with the right fitting. works great too
Old 12-22-2009, 07:59 AM
this was actually my plan lol glad someone already tried it and knows lol. Thanks guys for the help and input. Ill take a drive out to harbor freight and pick that fuel pressure tester today after work and try it out
ejfromwestbay
08-18-2010 05:44 PM
092eg6
12-11-2009 01:36 PM
SlowSlammedSedan
01-10-2009 06:50 PM
ronqqq
05-30-2005 09:39 AM
hwnstyle21
09-08-2002 02:14 AM
Quick Reply: Im stumped. How do you check fuel pressure eg hatch
