B series oil Dipstick tube issues
Old 07-21-2008, 11:20 AM
unrealwrc's Avatar
Default B series oil Dipstick tube issues
Ok so I have a b20vtec, and at this past track day at wmhm my oil dipstick tube can be removed while the engine is hot. after shutting of the car from a sessions I check my oil levels and my tube can be removed when trying to pull the dipstick out. BUT!!!, when the engine is cold you cannot remove the tube to save your life.
Does anyone else have this issue? I was going to quick steel it, but it seems that it does not leek on the track. Why is this happening?
Old 07-21-2008, 12:31 PM
Chris F's Avatar
Default Re: B series oil Dipstick tube issues (unrealwrc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unrealwrc &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I have a b20vtec, and at this past track day at wmhm my oil dipstick tube can be removed while the engine is hot. after shutting of the car from a sessions I check my oil levels and my tube can be removed when trying to pull the dipstick out. BUT!!!, when the engine is cold you cannot remove the tube to save your life.
Does anyone else have this issue? I was going to quick steel it, but it seems that it does not leek on the track. Why is this happening?</TD></TR></TABLE>
JB Weld or Hondabond.
A bunch of ITR's had this issue back in the day.
I figured it was gonna be another problem (burning up dipsticks, one of my old tricks on my turbo ITR) but yeah, the dipstick tube issue is common.
search for t00b through the archives (******** and their spelling. At least it's easy to find once you remember the keyword)
https://honda-tech.com/zerothread?id=232850
Old 07-21-2008, 12:59 PM
unrealwrc's Avatar
Default Re: B series oil Dipstick tube issues (Chris F)
mmm quick steel it is. Thanks alot Chris.
Old 07-22-2008, 03:51 PM
AW
AW's Avatar
honda bond it as when you need to rebuild motor, they need to take it out.
I used permatex grey and it stayed fine.
B16b-EJ8
16
03-11-2008 06:00 PM
Nameless Warrior
05-11-2007 08:31 AM
GoLowDrew
07-31-2006 07:10 AM
jarud3
28
11-04-2005 09:27 AM
XxRoCkMaNxNEOxX
11-28-2004 09:17 AM
Quick Reply: B series oil Dipstick tube issues
