Cant Split the case on my D-series
Old 04-28-2008, 06:16 AM
lulz
92BluEH-3's Avatar
Default Cant Split the case on my D-series
Alright im trying to get the case to split on my d-series tranny and i can slide he housing and box apart only about an inch but then it just gets hung up on something. Ive read about a counter shaft c-clip but only found info for it on b transmissions. Is there one on the d-series and how the hell do i get it off?
Old 04-28-2008, 02:04 PM
hatchling37's Avatar
Default Re: Cant Split the case on my D-series (92BluEH-3)
There is one on the D also. You have to take out the large sealing plug at the top (opposite end of the exposed mainshaft) of the case. Put your 3/8" ratchet in there and remove it. Then you have to get a pair of snap ring pliers or a couple of flat blades and spread that beotch apart. Then once it's expanded, tap the case and it should come off with minimal monkeying.
Old 04-28-2008, 06:00 PM
lulz
92BluEH-3's Avatar
Default Re: Cant Split the case on my D-series (hatchling37)
Yea i figured that out i just seen that plug and i thought hell its worth a shot. and whaddya know there it was.
oh and thanks for being intelligent and not a d-bag, like most of h-t
Old 04-29-2008, 07:56 AM
1992Si's Avatar
Also check the sticky at the top of this forum.
Old 04-29-2008, 08:01 AM
lulz
92BluEH-3's Avatar
Default Re: (1992Si)
ahhhh my bad i musta missed it
six7one
09-23-2006 01:47 PM
hondaj05
17
07-03-2006 01:19 PM
DC_RaceR
03-07-2006 04:18 PM
crexer
10-04-2004 06:00 PM
nsxmatt
06-04-2003 07:26 PM
Quick Reply: Cant Split the case on my D-series
