Transmission Topic Index/GOOD LINKS/ETC.
Old 03-14-2007, 02:24 PM
Go Tigers!
Bense's Avatar
Icon6 Transmission Topic Index/GOOD LINKS/ETC.
EDIT: I am locking this thread to prevent cluttering. Feel free to PM me any links that you'd like in here and i'll add them
Okay, So this is just like all of the other sub forum indexes, but this one is for the transmissions (duh )
I want good links in here with verified info, none of this fly by night "assumption" nonsense. With that said, I am going to provide links for the stuff that I have found to be helpful. Yes there will be some of my writeups, but that's just because I know of them and know where they are. This isn't a index of only my creations so please don't interpret it as that.
Mfactory LSD breakdown
https://honda-tech.com/zerothread/2380842
determining your gear ratios:
https://honda-tech.com/zerothread/2381004
how to tell what trans you have without reading any labels or anything
https://honda-tech.com/zerothread/1967953
Gears Grinding Explained:
https://honda-tech.com/zerothread/1916635
Hydro d-series zc hybrid transmission explained
https://honda-tech.com/zerothread?id=1449896
My B-series transmission page
http://bensebuilt.livejournal.com/2006/01/08
b-series cable ys1 trans vs hydro s4c trans:
http://hybrids.jp/forum/showthread.php?t=21540
b-series hydro internals in a cable ys1 case
http://www.outlawatvclub.com/u....html
my comparison between close-ratio gears and numerically higher final drives:
https://honda-tech.com/zerothread?id=1593351
Gear calculators:
http://www.teammfactory.com/gearcalculator.php *NEW* Jan 10, 2008
http://www.f-body.org/gears
http://www.fatboyraceworks.com/gears
http://autocrossing.com/cgi-bin/gearcalc.cgi
my mini howto on fine tuning your gearing for optimal 1/4 mile acceleration.
https://honda-tech.com/zerothread/1702219
Calculators for 1/4-Mile ET & MPH vs. HP and Weight
http://www.stealth316.com/2-calc-hp-et-mph.htm
d-series ratios (cable and hydro)
http://www.knology.net/~jedikl...s.htm
aquafina's 1/4 mile times with different gears on a d16y7
https://honda-tech.com/zerothread?id=1639804
my trans rebuild with infinitude gears + quaife LSD
https://honda-tech.com/zerothread?id=1645538
D transmission vs B transmission
https://honda-tech.com/zerothread?id=1751244
An excellent B-series transmission teardown & rebuild tutorial by member "Honda Bull"
https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/
A good b-series tranny rebuild + final drive swap
http://www.xm-parts.com/articles/hgear/gear.htm
Is your transmission knocking when you idle? Is it loud? I fixed mine (Pics + Parts)
https://honda-tech.com/zerothread/1999434
D-series S40 ('96 - '00) Failure pics with explanations
https://honda-tech.com/forums/transmission-drivetrain-127/d-series-s40-transmission-failure-pics-explanations-3038306/
Transmission bearing failures and causes explained
https://honda-tech.com/zerothread/2051578
H/F-series Mfactory LSD in an AWD CR-V transmission
https://honda-tech.com/forums/transmission-drivetrain-127/how-i-installed-lsd-crv-awd-transmission-3027124/
How to identify B-Series Cable Transmission Year Range
https://honda-tech.com/forums/transmission-drivetrain-127/how-identify-b-series-cable-transmission-year-range-3146036/
How to convert from tapered to ball bearings on Hydro GS-R/Type R transmissions
https://honda-tech.com/forums/transmission-drivetrain-127/how-convert-taper-ball-bearings-hydro-gsr-type-r-transmissions-3160456/
B and H-series transmission stopper plate alignment
https://honda-tech.com/forums/showth...0#post49012580
B-series hydro ring gear swapping
you have two style of ring gears. LSD style and b16 style
the LSD style includes all of the hydro LSD ring gears including the 4.785 and the 4.4 that's found in the integras.
then you have the "b16" style. The b16 NON lsd differentials use the "smaller" style. Also the b18b integra uses
the same style, only it uses the 4.266 ring gear
finding the gear ratios of your gears
Countershaft C-Clip? Do this to spread the clip and then gently pry the trans housing off
Editing this thread, old thread was moved to brown hole as it got too cluttered
Reference for me: https://honda-tech.com/zerothread?id=1649302
Bense is offline
Old 02-05-2020, 07:09 PM
Go Tigers!
Bense's Avatar
Default Re: Transmission Topic Index/GOOD LINKS/ETC.
Updated IMGs to not use photobucket.
Bense is offline
AznXstazy
01-12-2014 06:21 PM
Kelly.
08-04-2013 06:14 PM
vanhela
05-28-2011 11:00 PM
0ptimus prime
11-10-2003 12:34 AM
Quick Reply: Transmission Topic Index/GOOD LINKS/ETC.
