Transmission Topic Index/GOOD LINKS/ETC.
EDIT: I am locking this thread to prevent cluttering. Feel free to PM me any links that you'd like in here and i'll add them https://honda-tech.com/forums/images/smilies/emthup.gif
Okay, So this is just like all of the other sub forum indexes, but this one is for the transmissions (duh https://honda-tech.com/forums/images...s/emhammer.gif) I want good links in here with verified info, none of this fly by night "assumption" nonsense. With that said, I am going to provide links for the stuff that I have found to be helpful. Yes there will be some of my writeups, but that's just because I know of them and know where they are. This isn't a index of only my creations so please don't interpret it as that. Mfactory LSD breakdown https://honda-tech.com/zerothread/2380842 determining your gear ratios: https://honda-tech.com/zerothread/2381004 how to tell what trans you have without reading any labels or anything https://honda-tech.com/zerothread/1967953 Gears Grinding Explained: https://honda-tech.com/zerothread/1916635 Hydro d-series zc hybrid transmission explained https://honda-tech.com/zerothread?id=1449896 My B-series transmission page http://bensebuilt.livejournal.com/2006/01/08 b-series cable ys1 trans vs hydro s4c trans: http://hybrids.jp/forum/showthread.php?t=21540 b-series hydro internals in a cable ys1 case http://www.outlawatvclub.com/u....html my comparison between close-ratio gears and numerically higher final drives: https://honda-tech.com/zerothread?id=1593351 Gear calculators: http://www.teammfactory.com/gearcalculator.php *NEW* Jan 10, 2008 http://www.f-body.org/gears http://www.fatboyraceworks.com/gears http://autocrossing.com/cgi-bin/gearcalc.cgi my mini howto on fine tuning your gearing for optimal 1/4 mile acceleration. https://honda-tech.com/zerothread/1702219 Calculators for 1/4-Mile ET & MPH vs. HP and Weight http://www.stealth316.com/2-calc-hp-et-mph.htm d-series ratios (cable and hydro) http://www.knology.net/~jedikl...s.htm aquafina's 1/4 mile times with different gears on a d16y7 https://honda-tech.com/zerothread?id=1639804 my trans rebuild with infinitude gears + quaife LSD https://honda-tech.com/zerothread?id=1645538 D transmission vs B transmission https://honda-tech.com/zerothread?id=1751244 An excellent B-series transmission teardown & rebuild tutorial by member "Honda Bull" https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/ A good b-series tranny rebuild + final drive swap http://www.xm-parts.com/articles/hgear/gear.htm Is your transmission knocking when you idle? Is it loud? I fixed mine (Pics + Parts) https://honda-tech.com/zerothread/1999434 D-series S40 ('96 - '00) Failure pics with explanations https://honda-tech.com/forums/transmission-drivetrain-127/d-series-s40-transmission-failure-pics-explanations-3038306/ Transmission bearing failures and causes explained https://honda-tech.com/zerothread/2051578 H/F-series Mfactory LSD in an AWD CR-V transmission https://honda-tech.com/forums/transmission-drivetrain-127/how-i-installed-lsd-crv-awd-transmission-3027124/ How to identify B-Series Cable Transmission Year Range https://honda-tech.com/forums/transmission-drivetrain-127/how-identify-b-series-cable-transmission-year-range-3146036/ How to convert from tapered to ball bearings on Hydro GS-R/Type R transmissions https://honda-tech.com/forums/transmission-drivetrain-127/how-convert-taper-ball-bearings-hydro-gsr-type-r-transmissions-3160456/ B and H-series transmission stopper plate alignment https://honda-tech.com/forums/showth...0#post49012580 B-series hydro ring gear swapping you have two style of ring gears. LSD style and b16 style the LSD style includes all of the hydro LSD ring gears including the 4.785 and the 4.4 that's found in the integras. then you have the "b16" style. The b16 NON lsd differentials use the "smaller" style. Also the b18b integra uses the same style, only it uses the 4.266 ring gear ################################################## ##### finding the gear ratios of your gears https://cimg8.ibsrv.net/gimg/honda-t...5331deb1fd.jpg Countershaft C-Clip? Do this to spread the clip and then gently pry the trans housing off https://honda-tech.com/forums/images/smilies/emthup.gif https://cimg3.ibsrv.net/gimg/honda-t...0c91bb2f21.jpg Editing this thread, old thread was moved to brown hole as it got too cluttered Reference for me: https://honda-tech.com/zerothread?id=1649302 |
Re: Transmission Topic Index/GOOD LINKS/ETC.
Updated IMGs to not use photobucket.
