car wont heat up
Old 02-23-2005, 06:49 PM
whitecrx's Avatar
Default car wont heat up
my water temp gauge wont go up and im pretty sure both the gauge and the thermostat are working also my heater doesnt seem to heat which makes sense since the water isnt hot
anybody have any suggestions i hooked both hoses up, opened the valves and just took out a kink in one of the hoses and still no heat
hahaha
better get my defroster working so i dont run into someone like i did today
Old 02-23-2005, 07:16 PM
EP3_05's Avatar
Default Re: car wont heat up (whitecrx)
Does the lower radiator hose get warm after the car is running? to me it sounds as if the thermostat is bad.
Old 02-23-2005, 07:31 PM
StupidSlowRSX's Avatar
Default Re: car wont heat up (91civic)
Do you even have a thermostat? If you dont have one it will take the car a year to warm up.. Which can be a bad thing since honda heads are alluminum. It creates hot spots in the head which will eventually lead to the head cracking..
Old 02-23-2005, 07:33 PM
whitecrx's Avatar
the top one heats up, but ill have to check the bottom one tommorro its very possible that the thermostat isnt working, is there any way to tell besides having to take it out and put it in a pot of hot water?
Old 02-23-2005, 08:38 PM
coot_er's Avatar
dude, it cost like $14. just replace it already. most likely your problem will be solved, worst case senerio you spent $14 to narrow down your problem.
Old 02-23-2005, 09:07 PM
520_Motorsports's Avatar
Default Re: car wont heat up (coot_er)
don't think that would be a t-stat. the car would overheat if it was bad and the guage would read that the vehicle is over heating because there would be no flow in the system and the temp guage is on the side of the head. missing t-stat or super good radiator.
Old 02-23-2005, 09:15 PM
coot_er's Avatar
Default Re: car wont heat up (fastlx-i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastlx-i &raquo;</TD></TR><TR><TD CLASS="quote">don't think that would be a t-stat. the car would overheat if it was bad and the guage would read that the vehicle is over heating because there would be no flow in the system and the temp guage is on the side of the head. missing t-stat or super good radiator. </TD></TR></TABLE>
not always true. his t-stat is probably stuck OPEN. i had the same thing with my car, it wouldn't heat up. i replaced the t-stat, problem solved.
Old 02-23-2005, 09:22 PM
No tears. Only dreams, now.
VashTheStampede's Avatar
I've got the same prob. Temp sending unit malfunction.
Old 02-24-2005, 08:32 AM
strictlyimport's Avatar
Check the radiator fluid, if it looks like chocolate milk, you have a blown head gasket. When this happens, the car will not heat up to normal temp, or at least it will take a long time. Be sure to check it, as it could lead to more serious problems in the long run............
Old 02-24-2005, 02:29 PM
whitecrx's Avatar
Default Re: car wont heat up (strictlyimport)
thanks for all the ideas hopefully something works
Old 02-24-2005, 03:00 PM
j_max420's Avatar
it sounds like your thermostat is stuck open, try replacing it and flushing your cooling system, and heater core, but do it seperatly
Old 03-30-2011, 02:16 PM
Modell's Avatar
My car is doing the same. Gonna replace thermostat asap
dantamparacer
08-05-2010 06:51 PM
Dunc
07-22-2006 08:42 AM
pentaq
09-13-2005 03:19 PM
bumthology
11
12-11-2004 11:23 AM
planeman01
10-28-2002 03:22 PM
Quick Reply: car wont heat up
