NEED HELP ASAP. KNOCK SENSOR CODE
Old 01-12-2008, 06:52 PM
97eksoldier's Avatar
Default NEED HELP ASAP. KNOCK SENSOR CODE
hey guys i need help..i have a 97 ek with a mini swap. adn im throwing a P0325 which is the knock sensor code..im running a d16y7 block and tranny with a d16y8 head and manifold and a P2E ecu. Well i guess my block is not equpt with a knock sensor. and my ecu is looking for it, therefore throwing a code. Well i have state ref in 2 days on monday and i need to get rid of the light.. is there any way to trick the ecu into thinking there is a knock hooked up..for instance like wire up 5 volts to it or something.. i did that for the ftp code it was throwing wired up 2.5v and the code disappeared. i dont have money to buy a sensor and tap it in or the time it takes to order one. so can someone please help me and tell me how or if it is possible to trick the ecu into thinking i have a knock and to clear my code.
thanks in advance guys.. any help would be greatly appriciated..thanks
Old 01-12-2008, 07:15 PM
Default Re: NEED HELP ASAP. KNOCK SENSOR CODE (97eksoldier)
please help..does anyone at least know how much voltage it recieves?????
Old 01-12-2008, 07:29 PM
pdiggitydogg's Avatar
just put a knock sensor on the block...seems completely obvious to me
drill and tap one of the blanks
Or you could have....SEARCHED
https://honda-tech.com/zerothread?id=1181854
Jonzo
06-25-2005 11:28 AM
noob23
08-27-2004 03:59 PM
99spanishGT
03-26-2004 12:40 PM
TRhatchCRAP
10
08-10-2003 11:52 AM
jdmciviceg
06-09-2002 07:56 PM
Quick Reply: NEED HELP ASAP. KNOCK SENSOR CODE
