Need help Code 23!
Old Aug 26, 2004 | 06:52 AM
noob23's Avatar
Default Need help Code 23!
I have an 88 CRX w/ a JDM B16 swap. It's throwing code 23, which I know is the knock sensor. The light doesn't always come on, but the ecu is still flashing the code. Vtec still engages, which I thought wasn't supposed to happen with a code 23. What should I check? Any help would be greatly appreciated.
edit: I'm running a PR3, if it makes a difference.
Modified by noob23 at 10:05 AM 8/26/2004
Old Aug 26, 2004 | 09:17 AM
dabig1's Avatar
Default Re: Need help Code 23! (noob23)
if you have obd1 you can have the knock sensor and still get vtec,try searching on how to fix your knock sensor or just by a new one.
Old Aug 27, 2004 | 02:06 PM
noob23's Avatar
I did a search...nothing real helpful. I tried resetting the ecu...no luck. If the car is obd0 can I run without the knock sensor?
Old Aug 27, 2004 | 03:17 PM
hatchi's Avatar
check your wiring to see if you wired it in the right spot
Old Aug 27, 2004 | 03:59 PM
TIRENECK's Avatar
Default Re: Need help Code 23! (hatchi)
haha I have the same problem.
antballs420
Feb 20, 2006 06:35 PM
calgone47
Oct 6, 2004 11:46 AM
roadawg
Feb 21, 2004 09:31 AM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
jdmciviceg
Jun 9, 2002 07:56 PM
