DIY: tail light gasket for EK hatch WITH printable template (no more water in trunk)
Old 10-17-2006, 06:33 PM
tommyj's Avatar
Default DIY: tail light gasket for EK hatch WITH printable template (no more water in trunk)
After weeks of having water in the trunk of my EK hatch, I determined the problem was the tail light gaskets. Here are the steps I used to make my own homeade gaskets.
things needed:
1. tape
2. scissors
3. 4 sheets of craft foam (.75 a sheet)
4. computer paper
5. marker/pen
6. clear silicone (optional)
7. template (download link is below)
1. download the template I made
2. Unzip and open "bottom.pdf" and "top.pdf" with adobe acrobat reader
3. print both pictures on 11"x8.5" paper using these printer settings:
-turn off page scaling
-turn on auto-rotate & center
4. cut out both pieces and all holes
5. tape template together
6. trace template on craft foam using marker or pen
7. swap taillight gaskets out
8. use clear silicone where necessary for added protection
OPTIONAL: I doubled up on the foam and put sealant inbetween them for a thicker gasket
Modified by tommyj at 8:57 PM 10/26/2006
Old 10-24-2006, 05:03 PM
SHG_Beans's Avatar
Pretty sweet. Maybe i'll return the ones i just bought from honda and do it myself. Is clear silicone the adhesive i should use to hold the gasket to the taillight? I noticed when i took mine apart i saw that it had been glued on.
Old 10-24-2006, 08:08 PM
tommyj's Avatar
Default Re: (ek gripper)
Silicone will work just fine for a sealant.
It has been a few weeks now, and no water is in my trunk.
Old 10-24-2006, 08:30 PM
SHG_Beans's Avatar
Awesome! I can't wait to be able to say the same.
Old 11-02-2008, 07:19 AM
ib420phil's Avatar
Default Re: DIY: tail light gasket for EK hatch WITH printable template (tommyj)
Does anyone have the tail light gasket template? The link on this thread is no good.
Old 05-01-2022, 06:45 PM
RED(not)ROCKET's Avatar
Icon3 Re: DIY: tail light gasket for EK hatch WITH printable template (no more water in tru
Made up a printable template of my own as the link to the one attached to this thread by @tommyj is no longer available.
Few little instruction on my post below regarding getting it to print at the correct size/scale
https://honda-tech.com/forums/lighti...plate-3363501/
@ib420phil ,although you asked for a template back in 2008, here is a template on the off chance you're still in need lol
SpecialRequest
06-05-2015 06:37 AM
dth0ng69
11-23-2009 01:54 AM
sil04ver
11-18-2008 06:35 AM
JLEK
12-26-2006 07:20 AM
Phatch99
28
04-01-2004 05:57 PM
Quick Reply: DIY: tail light gasket for EK hatch WITH printable template (no more water in trunk)
