oil weight
Old 11-13-2012, 10:19 AM
tyrel-gsrturbo's Avatar
Default oil weight
changeing my oil on my gsr turbo always used 10-30 royal purple and wondr if I could use a better oil? should I use a different weight or stick with 10-30? daily driven.
Old 11-13-2012, 01:41 PM
B20DelSol's Avatar
Default Re: oil weight
whatever brand you like...All engine oils (that you should be buying) that are available to consumers meet or exceed the API specification for your engine. This means that they will perform better than what your engine requires.
IMHO, I don't recommend Royal Purple. Their base stock is comparable to mobil 1 and you are paying more for it.
If you want quality synthetic oil, I would say stick with Amsoil or Redline
If you want conventional...most will do, I just pick a good name brand like Castrol, pensoil, Valvoline, or mobil.
But what do I know...I don't go to school for chemical testing, I have only read reviews online so that information may not be true, I am a certified ASE parts specialist for Passenger cars and light trucks, and base most of what I just said on personal preference.
In the end, you should be fine. if you engine is happy with it, you should be too.
Old 11-13-2012, 05:40 PM
civicguy395's Avatar
Old 11-13-2012, 06:06 PM
Retired Moderator
EsotericImage's Avatar
I use Shell Rotella 10/30 when i was boosted. had alot of additives and good zinc content.
Can be found on special for 12.99/gal at most local auto parts stores
Old 11-15-2012, 07:04 AM
SilverEK96's Avatar
For the guys that use Shell Rotella. What would be the better choice to use between the T5 10/30 synthetic blend or Rotella T 15/40 triple portection??
Old 11-15-2012, 07:33 AM
Turbo-LS's Avatar
I personally run Rotella T5 10w30 semi synthetic or Rotella T6 10w40 full synthetic in my car and works very well.
Old 11-15-2012, 07:45 AM
4cylfiend's Avatar
Rotella is what alot of people run and have good success with it, especially if you are changing your oil on a frequent basis.
I run Brad Penn 20w-50 in my car because I run e85 as well as looser p2w clearances and looser bearing clearances. Ethanol doesnt mix with oil so the added protection that the additive package in that oil provides, is necessary for me. Brad Penn is relatively inexpensive if you know where to look as well
Old 11-15-2012, 07:56 AM
SilverEK96's Avatar
Up to this point I always used Valvoline 10w30, but it looks like ill be making the switch over to Rotella finally. Also the price is way cheaper than all the other brands, even for the Rotella full synthetic blend. Wow! I cant believe its actually a win win situation for once.
Old 11-15-2012, 09:01 AM
XxRoCkMaNxNEOxX's Avatar
Rotella only comes in a full gallon compared to others that are 5QT.
I use Rotella T6 5w40 on my stock WRX and 15w50 Mobil 1 on the Honda
Old 11-15-2012, 09:23 AM
Retired Moderator
Ive read where Mobil1 oil is lesser quality now then the mobil1 of years ago..
less additives and i think they changed their base stock.. I cant remember all the details.. But it was enough for me to research and Rotella was my choice.
YoshiiEK
06-18-2008 11:44 AM
B-A-N-A-N-A-S
05-20-2005 06:34 PM
Blue-Civic-Hybrid
06-23-2003 03:19 PM
01PYTypeR#1140
06-19-2002 07:49 AM
Audipwr1
06-13-2002 01:25 PM
Quick Reply: oil weight
