what oil weight???
H-T Order of Merit
Re: what oil weight??? (s10w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s10w »</TD></TR><TR><TD CLASS="quote">it is now summer time and my brother is changing his oil. what oil weight should he get and what brand? thanks</TD></TR></TABLE>
Viscosity - you'll hear a lot of opinions here. The owner's manual says 5W30 is preferred at all temperatures.
Brand - again, you'll hear a lot of opinions. I happen to think that brand doesn't matter as much as deciding whether to use conventional oil, pure synthetic, or a blend. The advantage of synthetic (and, to a lesser extent, synthetic blends) is that they flow better when cold, and they are more resistant to breakdown when hot. The disadvantage is cost.
I use 5W30 Mobil 1 synthetic.
Ditto what nsxtacy said. I also use 5w-30 Mobile 1 synthetic. Seems like they burn off more compared to others, though. I usually read about .25-.5 quarts less for every 1500 miles.
You might want to search, because I'm sure there are a few threads on this.
Re: (Viper8L488)
I burn a ton of Mobil1 5W30. I usually end up adding at least a quart or two between oil changes.
Every time I hit VTEC I think I burn a couple tablespoons.
Re: (filmmker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filmmker »</TD></TR><TR><TD CLASS="quote">10w30. good weight.</TD></TR></TABLE>
That's what I use, works great, never had any problems and I live in TX.
Re: what oil weight??? (200cs)
i havent tried it but i read that redline oil actually makes horsepower, im skeptical, but may try it soon, costs an arm and a leg tho.
currently using 10w30, may try synthetic soon
5w30 will do for stock/nearly stock motor/setup. and it don't have to be synthetic.
<-- 15w50 for this summer.. right now a mix of 5w40/15w50 comging from earlier spring oil change
Re: what oil weight??? (justinsouza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinsouza »</TD></TR><TR><TD CLASS="quote">oil actually makes horsepower</TD></TR></TABLE>
at cost of providing less lubrication, thinner oil should obviously allow engine to move more freely, isn't that the reason race cars are starting to run thinner oils and multi-viscocity, keep in mind they sometimes and can afford to replace engine every race. theres a reason, 5w30 10w30 like oils are energy concerving, and they're still fine for stock type engine, i woudol'nt run 5w20 just to save on fuel and possibly .02 more hp.
Re: what oil weight??? (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">and possibly .02 more hp.</TD></TR></TABLE>
The difference is not nearly that small...... but good earl off the autozone shelf will protect your motor just fine.
I need some of this: http://store.yahoo.com/ltbmoto....html in 0w20
The rated viscosity doesnt tell the whole story either.
Re: what oil weight??? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
The rated viscosity doesnt tell the whole story either.</TD></TR></TABLE>
thats true and a good point
HUBB
12
04-24-2004 01:53 PM
