What injector seals are to be used on Edelbrock Victor X Intake Manifold?
Old 03-25-2017, 10:49 AM
gert's Avatar
Default What injector seals are to be used on Edelbrock Victor X Intake Manifold?
hi little question do's anyone now where i can order bigger seals for my edelbrock victor x?
Old 03-25-2017, 02:50 PM
It's wU to the sOLdiEr!
justYncredible's Avatar
Default re: What injector seals are to be used on Edelbrock Victor X Intake Manifold?
iirc i just used my stock seals on mine.
Old 03-26-2017, 04:23 AM
gert's Avatar
yes this are the oem seals from gsr engine but are to small ..
Old 03-26-2017, 09:40 AM
2kdrift's Avatar
I believe there are 2 different types of seals, what year was the gsr?
I believe OBD2 seals are different then OBD1 seals. OBD1 should be the ones you want . At least I know this was how it was with my d series
Old 03-26-2017, 11:12 AM
gert's Avatar
owke thank you gonna check it!��
Old 03-27-2017, 10:04 AM
B and B's Avatar
Curious what brand injectors you will use?
This isn't as easy as it looks sometimes....I noticed my ID725's were a very sloppy fit (ITR intake)..I ordered every "cushion" and "seal" I could find, and ended up making some nylon flat washer type units to keep the injector from unevenly distorting the seals when rail was tightened.
My **** is kind of thrown together, but I wonder how many people have boost leaks there, cuz it was hard to get right in my case.
It is now, but took some doing. Honda shows two parts in the bore, I don't remember how it looked when we had a GSR.
this is for a 94.
I ordered #4 also and its a thin little ****.
The bores under your seals look rough, btw...what do they look like with nothing in there?
Old 03-27-2017, 10:05 AM
i have an obd1 gsr and i think they are bigger than the obd2 in which why i might not have had an issue.
Old 12-07-2018, 08:27 AM
dave7's Avatar
Looking for this kit. Let me know if anyone has it for sale.
Old 06-15-2019, 11:52 PM
Moderator
TheShodan's Avatar
Default Re: What injector seals are to be used on Edelbrock Victor X Intake Manifold?
This will be closed for no additional content, but at least it's been bumped so that if one comes up in a few years, you can be contacted.
Cheers.
Turbo_Mike
04-04-2009 09:07 AM
mikegeezy
03-05-2007 09:10 PM
a1320addict
08-08-2006 08:18 PM
turboteg2nv
08-27-2004 01:19 PM
InTeGrA B18b1
05-12-2003 01:53 PM
Quick Reply: What injector seals are to be used on Edelbrock Victor X Intake Manifold?
