70mm BBk throttle body idling issue!
Old 02-27-2006, 06:53 PM
iBrandon's Avatar
Default 70mm BBk throttle body idling issue!
I recently installed my turbo built gsr motor into my integra...and now daily driving it with out turbo..running stock pump and fuel injectors..
Anyways...my car idles perfect up til it hits the peak normal temperature which is little below the half mark on the gauge....when it hits there my idel flucuates from 1000-1500...i dont know why it does it...anything below that idles perfect...
i changed my thermostat...it was sticking before and not warming up...i changed my map sensor, cleaned out the iact, adjusted the throttle cable, played with the screw on the throttle body...chaeck for vaccum leaks..
im thinking it could be a vaccum leak, but if it was a vaccum leak wouldnt it flucuate at any temperature and not just at peak normal temperature??...
any ideas would be great...im about to just tune the idle area myself to idle correctly...maybe the VE is greater since it has a bigger throttle body...but maybe not?
Old 02-27-2006, 07:04 PM
teg racer 877's Avatar
Default Re: 70mm BBk throttle body idling issue! (iBrandon)
what are you tuning with?
Old 02-27-2006, 07:35 PM
iBrandon's Avatar
Default Re: 70mm BBk throttle body idling issue! (teg racer 877)
im going either s300 or neptune when i get my turbo setup on...mean time...im messing around on crome...
CrazyFNG
02-16-2012 02:32 PM
hkrichard
04-27-2008 06:03 PM
hybridEj6
10-05-2006 11:23 AM
Initial DA6
08-29-2002 03:24 PM
Quick Reply: 70mm BBk throttle body idling issue!
