Garrett T61/ Gt40 Blowzilla 35r Compressor Wheel
t61/gt60 Garrett turbo In great shape no shaft play no damage barely used turbo. Come with 4 bolt .63 exhaust housing with a bolt on v band adapter. I am going to a 6262 instead Specs are below..
This is a special order turbo from Garrett. Cost from Garrett is around $880+
Asking 600 shipped
Garrett T61 (samecompressor wheel as GT35R aka GT3540R) Turbo with P trim or Stage 3 turbine wheel and T3 (Specify) A/R turbine Housing. This is a journal bearing unit with oil cooling only - Garrett factory assembled and balanced.
Compressor Specs: GT40 (same compressor wheel as GT35R aka GT3540R)
.70 a/r Comp. Housing 4" inlet / 2.5 outlet
61mm inducer/ 82mm exducer
flow: 65 lbs/min 832cfm
Turbine specs: T3
Turbine wheel: P-trim / Stage 3
360* thrust bearing standard
Asking 600 shipped
Turbine specs: T3
