alarm programming question.
i have a prestige alarm and i use it for the alarm, remote start, unlock/lock doors, and when i recently did my swap i had to unplug the alarm system. when i got done with the swap and go to hook the alarm back up it goes off and i try to disable it with my remote, but nothing. its like the remote forgot what to do. any help will be appriciated.
Old Fart
Re: alarm programming question. (tallyturbo)
You are correct, the brain has "forgotten" the remotes codes, you will have to reprogram the remotes, if you do not have a manual, find it here http://www.audiovox.com/webapp...brand= also if you turn on your ign. before you plug the alarm brain in it should do a "quiet power up" 94
Old Fart
Some alarms will go into alarming mode as soon as you "power them up" to avoid this turn on the ign., [so alarms ign. wire has power] and it should power up without going into alarming mode, [quiet power up] 94
