Legacy Amps
Old Jan 14, 2006 | 08:22 PM
harley06's Avatar
Default Legacy Amps
Are legacy amps any good? i just bought a legacy la590 for 60 bucks and i was wondering if its any good. how do i hook it up to mono because its running on stereo right now.
Old Jan 14, 2006 | 11:51 PM
hb420's Avatar
no
but you only paid $60 bucs. is it new? does it have a mono switch on it?
Old Jan 15, 2006 | 05:50 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">no</TD></TR></TABLE>
Old Jan 15, 2006 | 09:51 PM
harley06's Avatar
Default Re: Legacy Amps (harley07)
i have 2 12" and when i have them hooked up to the amp, my subs arnt hitting at the same time.
Old Jan 15, 2006 | 10:03 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley07 &raquo;</TD></TR><TR><TD CLASS="quote">Are legacy amps any good? i just bought a legacy la590 for 60 bucks and i was wondering if its any good. how do i hook it up to mono because its running on stereo right now.</TD></TR></TABLE>
Legacy = garbage.
If you only have $60, you are better off buying something used. Even a good quality, 15 year old used amp is going to be better than a new Legacy amp.
Old Jan 15, 2006 | 10:09 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harley07 &raquo;</TD></TR><TR><TD CLASS="quote">i have 2 12" and when i have them hooked up to the amp, my subs arnt hitting at the same time.</TD></TR></TABLE>
because you have them wired out of phase.
you know $60 can get you a pretty nice steak dinner...but not an amp. some food for thought.
Old Jan 15, 2006 | 10:24 PM
harley06's Avatar
Default Re: Legacy Amps (EBP_SI)
what u mean wired out of phase
Old Jan 16, 2006 | 12:34 AM
silentblackhat's Avatar
you have one of the subs wired up correctly, one of them not. if u have the speakers wired in series, make sure its from the + of the amp to the + of one sub(either one) then run the - of that sub to the + of the other sub then the - of that sub to the - of the amp.
If you have them wired seperate, make sure the + of both subs are running from the + terminals and the subs -'s are running to the - terminal of the amp.
If you have them wired out of phase, one sub will push out, while the other sub pushes in....adding those 2 directions = zero....which means when 1 sub goes in and the other goes out at a specific instance, it cancels the sound out.
Old Jan 16, 2006 | 01:52 AM
john666's Avatar
swapmeet brand so swapmeet quality
Old Jan 16, 2006 | 11:41 AM
. O M E G A's Avatar
3rd g3aR vTak
**** I woulda sold you my Rockford Punch 201s for $60!
Old Jan 16, 2006 | 07:51 PM
SloCrxDx91's Avatar
I have the 2 channel 2400 watt. I would hit 145+ db. But the question is are legacy amps good and the answer is no. The are cheap low quality distorted amps. If you are serious about car audio get a class d amp. Thats what i would do.
Old Jan 17, 2006 | 09:52 AM
Where did u get it? I found them on the net for $60 also...i see the alpine amp i have selling for 3 times that, and my amp is a few years old
skingfreak
Audio / Security / Video
19
Feb 24, 2008 04:49 PM
4dr_GS-R
11
Sep 24, 2005 02:12 AM
harlen
Jun 3, 2005 01:05 PM
hondaZvic
17
Dec 14, 2004 08:38 PM
BuddyC
22
Apr 13, 2004 02:58 PM
