Clutch Master Cylinder
Old 02-13-2011, 09:22 AM
Miracle11's Avatar
Default Clutch Master Cylinder
So the other day when I was driving my clutch peddle went all the way to the floor. Now after looking at it I had come to the conclusion it was my master cylinder and replaced it. Well now that its replaced I am having trouble with the peddle still going down to the floor board.
So does anyone have any ideas of what to check next? The clutch line still good. We bled the clutch line and still have the problem of it going to the floor board. Any ideas on what i need to do or check?
Old 02-13-2011, 04:36 PM
1998GsRIntegra's Avatar
Default Re: Clutch Master Cylinder
I use this term loosely, but "typically" when a clutch master cylinder is replaced the slave cylinder is also replaced. I would consider changing it out as well.
Are you sure you bled it properly?
Video on replacing honda clutch hydraulics if you want to watch it: http://www.youtube.com/watch?v=c-m5F...layer_embedded
Old 02-13-2011, 06:38 PM
98sierra's Avatar
^^this. it takes FOREVER to bleed systems
zach1288
01-21-2010 03:16 PM
hYbRiD EeEkAy
08-07-2008 11:27 AM
obuhmyuh
04-19-2008 02:14 PM
RDAYA0
12-14-2006 05:31 PM
FuNkDrSpOt
10-10-2006 09:48 PM
Quick Reply: Clutch Master Cylinder
