clutch / transmission problem
i was driving to work today and i lost clutch pedal pressure and was unable to select gears. Clutch is almost brand new (about 2 months driving on it), and my clutch master cylinder was completely full. (Kind of a brownish color though, not the usual golden).
I ordered a new clutch slave cylinder from kragen.
Does anyone have any other suggestions?
Re: clutch / transmission problem (obuhmyuh)
Bleed the system and check for leaks in the line.
Have someone step on the clutch pedal while you pull back the boot covering the slave cylinder and and see if the slave cylinder moves at all.
If all else fails after you replace the slave theres a 99% chance its your Master. Good luck.
Re: clutch / transmission problem (V-tecman37)
a leak in the clutch line would lead to my master cylinder going dry, when i opened it it was full. but you think its my master cylinder and not my slave?
i replaced them both, QUITE THE PAIN IN THE *** BY THE WAY (master cylinder mainly) working under the dash... seems to be fixed thanks for now! haha
gooblinn258
01-18-2014 05:02 PM
hYbRiD EeEkAy
08-07-2008 11:27 AM
