clutch master or clutch slave cylinder?
Old 08-07-2008, 11:13 AM
hYbRiD EeEkAy's Avatar
Default clutch master or clutch slave cylinder?
so i was driving to dade two nights ago and my clutch pedal felt like it was sticking and then all of a sudden i lost all the pressure in the pedal and couldnt get the car in gear. i guess the clutch is still engaged and wasnt able to disengage? anyway, got the car home, clutch master cylinder reservoir was almost empty.. no signs of leaking from the slave or master and no signs of leakage under the pedal. traced the hardline running to the slave and found signs of leaking where the hardline turns to a soft line.
filled the reservior, tried pumping the pedal and no pressure. tried bleeding the system and it was fine.
any ideas as to wether it is the slave or master?
Old 08-07-2008, 11:27 AM
Hanmin's Avatar
if its leaking where the line turns soft, theres your problem. check the hose and check the connection.
Miracle11
02-13-2011 06:38 PM
obuhmyuh
04-19-2008 02:14 PM
anewfoundkevin
09-02-2004 04:56 PM
Pandahatch
12
08-24-2004 07:48 AM
Lei Siew Long
10-22-2002 10:43 AM
Quick Reply: clutch master or clutch slave cylinder?
