35mm replace to a 38mm
Old Mar 24, 2005 | 06:42 AM
fro's Avatar
fro
Default 35mm replace to a 38mm
i was wondering if a 35mm wastegate can be replaced with a 38mm wastegate or is a bigger size. the reason i was wonderin is because i have a 35mm wastegate that is broken and was looking at a new ones and seen 38mm and was wondering if it would work.
Old Mar 24, 2005 | 06:44 AM
Evanmb44's Avatar
Default Re: 35mm replace to a 38mm (fro)
you should be able to bolt it up to the same flange
Old Mar 24, 2005 | 06:47 AM
fro's Avatar
fro
Default Re: 35mm replace to a 38mm (Evanmb44)
thanks thats what i need to know
RadekSkylark
Welding / Fabrication
Oct 9, 2011 12:57 PM
d_mina
Feb 20, 2004 05:13 AM
Kidd_Stylez
Jul 20, 2003 07:32 PM
SilverS
Jul 24, 2002 09:29 PM
