Metal table?
Old Aug 12, 2004 | 10:51 AM
VWkila's Avatar
Default Metal table?
Do you need a metal table to MIG weld?
Old Aug 12, 2004 | 10:55 AM
Fab-Works's Avatar
Default Re: Metal table? (VWkila)
You dont need it. But it would be very helpful. With a metal welding table u just clip the ground to the table and lay the piece you are gonna weld on it.
Old Aug 12, 2004 | 10:59 AM
VWkila's Avatar
Default Re: Metal table? (anthonycn)
So, if you don't have a metal table, you'd ground straight to the work piece, right?
Old Aug 12, 2004 | 11:02 AM
BROOD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila &raquo;</TD></TR><TR><TD CLASS="quote">So, if you don't have a metal table, you'd ground straight to the work piece, right?</TD></TR></TABLE>
Yes
A clean surface on the metal table is important for a good circuit completion. A nice heavy welding/setup table is great but very diffuclt to move around and have in a small shop.
A nice light frame with a thinner plate steel top is a good compromise. (and by thinner I don't mean sheet metal )
Old Aug 12, 2004 | 04:33 PM
dmotoguy's Avatar
Default Re: Metal table? (BROOD)
im welding up my table this weekend.. its THICK!
its been a pain in the *** to weld without it, been doing lots of stuff on the ground/on cinder blocks.. kinda sucked
Old Aug 12, 2004 | 05:45 PM
SJcivic's Avatar
If your using the table as a ground, then yes it has to be metal. If you ground it to the peice, then the table makes no difference.
Rich
Old Aug 13, 2004 | 03:21 AM
VWkila's Avatar
Default Re: Metal table? (SJcivic)
Does the whole table has to be metal? Or just the working surface top?
Old Aug 13, 2004 | 05:11 AM
B18C1CYA's Avatar
i would make all the table out of metal , i have one that i built about 6 years ago it is 32'' x 32'' and i made the top out of 3/16'' plate not to hard to move around but very strong
Tigfab
Welding / Fabrication
Feb 8, 2006 12:56 PM
RCautoworks
Jul 12, 2005 01:13 PM
AZNracerx1989
May 31, 2005 10:34 PM
RCautoworks
Oct 5, 2004 09:20 PM
mushu315
21
Jul 23, 2004 04:47 AM
