Cleaning before weld
Old Feb 5, 2006 | 06:37 PM
Tigfab's Avatar
Default Cleaning before weld
After I cut a tube wiht a chop saw then weld it, the welds allways come out black. I figued it was a heat issue. But when I weld 2 pieces that havnt been cut together I get great clean welds with alot of color. I figure its a cleaning issue, what do you guys do to prep the metal before weldling?
Old Feb 5, 2006 | 08:46 PM
blueoval557's Avatar
Default Re: Cleaning before weld (Tigfab)
Wipe it down well with lacquer thinner, or if your TIG welding, use acetone. Also, make sure you take the mill scale off, if your welding plate steel.
Kyle
Old Feb 5, 2006 | 08:56 PM
tony1's Avatar
Default Re: Cleaning before weld (blueoval557)
Don't get the acetone on your welding gloves while you're cleaning, it'll burn! lol don't ask me how i know that!
Old Feb 7, 2006 | 11:35 PM
fastzepplin's Avatar
lol
Old Feb 8, 2006 | 12:26 AM
Eddiebx's Avatar
Default Re: Cleaning before weld (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Don't get the acetone on your welding gloves while you're cleaning, it'll burn! lol don't ask me how i know that! </TD></TR></TABLE>
i bet you have the burn marks to prove it
Old Feb 8, 2006 | 12:58 AM
hondaapi's Avatar
Default Re: Cleaning before weld (Eddiebx)
Or better take care not to put it onto your clothes. I know why I say this ;-)
Old Feb 8, 2006 | 04:06 AM
jon volk's Avatar
Dont get the acetone on your welding helmet lens either, itll start dissolving the plastic I put my helment down on a rag w/ acetone and when I picked it up the rag was sticking to the lens cover.
Old Feb 8, 2006 | 12:46 PM
bigTom's Avatar
what a b*tch... y dont u go and cry about it some more...
personally i use the 3M roloc surface conditioning pads to clean off most metals before welding it... had good luck with it and the surfaces always come out perfect...
Old Feb 8, 2006 | 12:56 PM
david@didrace.com's Avatar
Default Re: Cleaning before weld (bigTom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigTom &raquo;</TD></TR><TR><TD CLASS="quote">
personally i use the 3M roloc surface conditioning pads to clean off most metals before welding it... had good luck with it and the surfaces always come out perfect... </TD></TR></TABLE>
Rolocs are expensive though for how little use I get out of them. Usually they're like $.50-.75 a piece. I found a company called Klingspor that sells boxes of 100 knockoff 3M ones for $35. Usually I spend $40 or higher on a box of 25 of the 3M ones.
PlusOne
Welding / Fabrication
23
Sep 6, 2007 08:29 PM
RCautoworks
Jul 12, 2005 01:13 PM
juicedse
Oct 15, 2004 01:28 PM
EGPHANTOM
Oct 13, 2004 11:36 PM
DANgerous
Mar 20, 2004 07:40 AM
