AWD EJ2 Build
Old Feb 10, 2013 | 01:58 PM
  #976
purplecivicturbo's Avatar
Default Re: AWD EJ2 Build
That is completely true, it will take on a hell of alot of water..
Ive designed an air box for the rear, which the intakes will feed. There will be a dividing plate to stop water hitting the filter, so the water will essentially fill the bottom of the airbox and drain out of a hole in the bottom. It shouldnt be an issue at all..
Old Feb 11, 2013 | 03:57 AM
  #977
albertodsa's Avatar
what do you things if you add an scoop in the sunroof intake? like rally car???
Old Feb 12, 2013 | 12:44 AM
  #978
LS-Rman's Avatar
Here is a thought, I found a build on Pirate4x4 were a guy built a tube buggy for his daughter using a Honda D-series engine. The engine was turned so that the front faced the back of the buggy. He had a custom driveshafts made, so that on one end was the inner cv joint and the other was the yoke for a Toyota axles. You could use a front wheel drive transaxle instead of the RT4 transmission. This might open up better options for gearing and limited slip.
Old Feb 28, 2013 | 06:31 AM
  #979
albertodsa's Avatar
any news?
Old Mar 10, 2013 | 02:54 PM
  #980
Flexer's Avatar
OP, By making an adapter plate to flip the transfer case around didn't that space out the transfer case making it so that the input shaft doesn't go as far into the transmission? How thick is this adapter plate and are you worried because less splines are engaged? Or am I thinking about this totally wrong?
Old Mar 24, 2013 | 08:45 AM
  #981
Jason Liu's Avatar
wow
Old Mar 26, 2013 | 05:35 AM
  #982
SOCKinside's Avatar
wow!
Old Mar 31, 2013 | 05:56 AM
  #983
archys7's Avatar
That is sick project, can't wait for my 4wd hatch conversation :-)
Old Apr 5, 2013 | 05:10 AM
  #984
albertodsa's Avatar
hey dude, what happen with this proyect! long time ago without any update
Old Apr 8, 2013 | 12:45 PM
  #985
Vagitarian's Avatar
Hopefully finally gave up
Old Apr 14, 2013 | 03:46 PM
  #986
Shelfeesh's Avatar
Hopefully he's just been busy with the new job and doesn't time to post. This thing is amazing.
Old Apr 17, 2013 | 09:25 AM
  #987
the_unknown's Avatar
GDD Lonely Krew
Hopefully your heartbeat finally gives up, stupid vag....
There is more innovation and skill in this build then you could possibly comprehend, your sn says it all..Douche of the worst kind.
come back to us Purplecivicturbo!!
Old May 3, 2013 | 04:17 PM
  #988
Naterror's Avatar
As much as Chris has invested in this project, I seriously doubt he's given up on it.
Old Jun 16, 2013 | 01:03 AM
  #989
maddix's Avatar
awesome build
Old Jul 29, 2013 | 02:10 AM
  #990
wantboost's Avatar
Who is Mr Robot?
I'm very interested in your rear wing setup. Mostly the air brake function
My civic is mostly a dd/highway speed run/hardcore mountain run and road course car and I need all the supplementary braking I can get. I don't simply want it actuated all the time, only above a certain speed then it retracts. I thought about making a wing that's longer, to maximise the braking effect and maybe modify the uprights enough to get the wing 90 degrees to the road surface, although I'd need to figure out how much force would be exerting on the wing so I don't shatter it
I don't really need the height adjustment feature as I'll make more than enough torque to negate drag from downforce
Old Mar 9, 2014 | 12:14 PM
  #991
96GeeSR's Avatar
Anything new with this?
Old Mar 13, 2014 | 01:06 AM
  #992
I had originally thought about this, however, the roof scoop would seriously make a mess out of the airflow over the roof and eventually the rear wing- which is what i dont want. What i did was to put the largest NACA ducts i could in without impeding the headroom (im short so generally its fine). The idea with this is that NACA ducts create only a small disturbance to the airflow, however when the airbox becomes low pressure- relative to the ambient pressure, the ambient pressure will actually force air into the ducts and airbox.
No not at all, you are correct. It was a risk i decided was worth it.. I want to prove the idea using this method - with approx 75% engagement on the gear. Then once thats done, manufacture a new one to accomodate the additional length required by the spacer thickness (-12mm)
Get it done! I had awesome fun playing with it, turning a rear wheel and watching a front wheel turn is quite novel on a car you always knew as FWD.
Thanks for your support- you are entirely correct. My new job has seen me rather busy..
Also thanks for your support mate, i am back now!! The issues keeping me from progressing was money, compounded by this new job.. But hopefully i can get back to work.
No not given up.. I firmly intend to finish and enjoy this car. The next hurdle is to build a rotisserie for the car, 3D scan the whole thing, design the new body and then (somehow) manufacture it.
Thats a good point, its what i did with mine. However from a stability point of view, having the wing meet 90 degrees during heavy braking may be very dangerous.. What you have to remember is that the wing is generating rear downforce, if you simply flipped it to 90 degrees yes it will create a massive amount of drag- but the airflow will stall, you will loose all the downforce it is generating, resulting in a change in the handling of the car. It is better to either model the wing profile using a computer to determine the maximum angle of attack without causing flow separation, or to experiment with it..
To all those people (if there are still any) who have been waiting for me to post on here, i apologise. Things have been rather hectic. I have started a new job in the R&D future projects department of a major defence contractor, the new job is quite demanding and it has taken a while to get on top of it all.. Also had some various setbacks at home, affecting both time and money.
I am hoping to get back on top now, i have a few things to sort out first but i intend to get back to the car in the following weeks / months..
Chris
Old Mar 15, 2014 | 10:25 AM
  #993
TPRD831's Avatar
just spend hours reading this thread AMAZING WORK is an understatement my friend
Old Mar 15, 2014 | 03:27 PM
  #994
SovXietday's Avatar
Chris
I hear you on that one man, I haven't even seen my car for the past 4 months.
What are you planning on using to drive the rear wing up and down? I have a couple of ideas of my own, but I have a drag race car. A lot of times with us, under braking at high speeds, these cars will lift completely off the rear wheels. I'm thinking about designing a rear wing brake that helps slow the car as well as keeps the wheels on the ground.
Also need to figure out some sort of controller for that, should be interesting considering I'm an ME and my electrical background is eh.
Old Mar 17, 2014 | 04:45 PM
  #995
KevinEF7's Avatar
Just read 40 pages to find out the project is still 3+ years out? Shiiiiit
Old Mar 17, 2014 | 09:31 PM
  #996
myEGhatch15's Avatar
I as well just read through absolutely everything about this car and I only have one thing to say. If only you could been around when Honda itself was designing these cars, you definitely could have shown them exactly how to make the ideal honda. But off of that I honestly think this is the most detailed, time consuming, head turning, jaw dropping, sickest build I have ever yet to see. It's because of guys like you who have that much knowledge and passion for cars that make the advancements we have today. Extremely impressed that it was far beyond worth reading through everything. Hope this build gets up and running again so we all can see this beastly civic out everyone to shame.
Old Jul 1, 2014 | 01:59 AM
  #997
soxle's Avatar
Can you put details on the dry sump moroso kit, please?
I have one (used) and I want complete it and put it on my engine.
thanx
Old Jul 27, 2014 | 01:48 PM
  #998
welfarepc's Avatar
Hey man, having problems with my COP box. Sent you a PM, would sure appreciate a reply. hehe. Noticed your website is down. :S
Old Aug 19, 2014 | 06:16 AM
  #999
Hello all.
Apologies again for my extended absence- hopefully that should be changing now.
The build of the car has pretty much stopped with work and financial commitments however i have made the decision to sell the whole engine except the turbo and wastegates. The idea with this is that i can sell the engine to try and make some money back, obtain a lower spec engine and complete the build with that money.
So if anyone is looking for a well built- very high HP engine, please let me know.
I dont expect the change in direction to go down well but unfortunately it is the only way i am going to finish the build and i know that people will not like the choice of engine so i am almost tempted to keep that to myself for a while.
The car will remain mid-engine, and computer controlled 4wd simply the engine will change. Fingers and toes crossed!
Old Sep 21, 2014 | 08:02 AM
  #1000
bdmy_yard's Avatar
awesome build :D
