AWD EJ2 Build
Old Apr 3, 2012 | 10:52 AM
  #776
purplecivicturbo's Avatar
Default Re: AWD EJ2 Build
Okie dokie
Time for an update..
Recently i have been very busy developing a new product. This is an extension of the coil on plug interface i have made which also allows the dizzy to be completely removed and replaced by the AEM EPM.
(leds represent spark outputs)
Showing emulated tachometer drive output
Okay my car.. Not a huge amount, apart from still waiting on parts to turn up. The passenger side rear wheel arch is now attached, and ive put a layer of fibreglass on the back to force it to retain the curve which the body has put on it. Ill be removing it and adding more reenforcement and using filler to make it smooth. Because of chassis flex, i wont be attempting to make them look permanent but they will look like perfect bolt ons. The drivers side was done tonight, under the watchful eyes of garrett..
Also had some time to suss out the rear diff control solution.. I stripped the diff down and removed all the hydraulics. Then i identified the 2 oil control orifices. I have drilled and tapped one for a blanking screw, the second i have drilled through to from outside and designed a plug i need to have turned. This will now allow me to supply oil externally..
Old Apr 3, 2012 | 11:00 AM
  #777
soxle's Avatar
You're brave! very interesting!
Old Apr 3, 2012 | 11:07 AM
  #778
meh you cant call me brave! you put rear wheel steering on yours!
Old Apr 4, 2012 | 06:25 AM
  #779
soxle's Avatar
Perhaps, I'm mad,
Perhaps, I think it's easier!
(Maybe both!) LOL
Good job, mate!
Old Apr 4, 2012 | 11:34 AM
  #780
to be honest think you (we) must be a bit mad to chop up a 20 year old car to put 4wd on it, with the intention to use it in anger if its ever finished lol
Old Apr 6, 2012 | 08:28 AM
  #781
albertodsa's Avatar
good look!!! when is the dead line to finish the project???
Old Apr 6, 2012 | 01:31 PM
  #782
thanks mate, as soon as possible... hopeful to paint it this summer
Spent ages today setting up the new milling machine.. Its only small but its superb, seems to be very accurate and will suit most of my needs, slowly but that doesnt really matter...
Old Apr 7, 2012 | 01:34 PM
  #783
Smokinsax's Avatar
The Boot
what a neat little machine! What kind of things are you making from the mill?
Old Apr 8, 2012 | 03:28 AM
  #784
It is rather neat..
Its not heavy duty by a long shot... But with a low enough feed rate it will do billet ali, very very slowly..
Ill be using it to make PCBs, machining brackets .etc for both my car and also stuff i do in my little business. I can also use it to cut plastic too..
Im also putting together a little package so my wife can use it to engrave things, as a little ebay venture..
Old Apr 8, 2012 | 08:32 AM
  #785
markspan6243's Avatar
Flattery Will Get You Everywhere
so is this gonna be real awd or is it gonna still be RT4WD?
Old Apr 8, 2012 | 08:50 AM
  #786
ef4dr's Avatar
That made me laugh a little bit. Im in that category as well.
Old Apr 8, 2012 | 09:12 AM
  #787
It is pretty similar to the Rt4wd.. The computer actuation makes it less like the dumb hydraulic system and more like the audi / haldex system..
The Audi TT, Golf R32, Audi S4 .etc all have a haldex based computer controlled torque transfer system usng an electro mechanical clutch. In very much the same way as im doing it.. Mine will just need a little bit of fine tuning.
Old Apr 8, 2012 | 09:13 AM
  #788
We should set up some kind of support group lol
Old Apr 8, 2012 | 10:05 AM
  #789
93egsir's Avatar
The AEM EPM only has 2 signal outputs that would match up with the honda tdc and the cyp. how are you going to make a ckp signal.
I have a hondata s300 and just installed the hondata coil on plug retrofit but I havent figured out how to generate the 3 missing signal so I can remove my dizzy.
p.s. my car is rt4wd gsr supercharged.
Old Apr 8, 2012 | 12:29 PM
  #790
i made a prototype box which took the epm signals, made up the missing one and provided emulated outputs for the ecu... I just sold one over here for testing..
Im using a similar thing for my epm, using a trigger wheel..
Old Apr 9, 2012 | 06:34 AM
  #791
Old Apr 9, 2012 | 07:23 AM
  #792
lol its not ideal, id have loved mid-engined awd (rear biased) but i had to draw the line somewhere lol..
Old Apr 10, 2012 | 02:30 PM
  #793
Woohoo
Finished the drive by wire...
The new servo arrived so i put it all together.. Unfortunately i didnt like the amount of slight jitter it had. I completely redesigned the computer and remade it.. It now uses 2 CPUs with a serial link to ensure that the noise is non-existant.. The resolution is so much higher and there is NO jitter..
Here is a pic of the finished computer, the case is still in need of labelling .etc though
I hooked my function generator up to the input and set it to do a sweep from 0 - 100% throttle on repeat for 2 hours.. The system held up perfectly!
Im in the process of building up the linkages now..
Only a basic video as i need to do alot of work on the throttle body itself
Old Apr 11, 2012 | 02:41 PM
  #794
acura_el2000's Avatar
I hope you take this car to a Honda dealership for an oil change at some point... just so you can watch the techs **** their pants! lol
Old Apr 11, 2012 | 03:02 PM
  #795
I dont think id even get that far.. A while back i had to get some odd parts, a mixture of integra / crv / civic vti .etc parts, apparently they cant even say "hello" to you without a chassis number...
Not that i generalise over all techs, this is just my experience lol
Old Apr 11, 2012 | 06:15 PM
  #796
Chaoic_Knight's Avatar
Can't wait to see your car running
Old Apr 11, 2012 | 11:22 PM
  #797
me too mate! Its been long enough..
I actually almost have enough to pay for the respray now.. im rather excited!!
Old Apr 14, 2012 | 09:34 AM
  #798
I have spent a week messing with this milling machine, there are a raft of issues with it (being from china). Noise issues, interface problems with a laptop (lower voltage parallel port) .etc
I have moved the VFD (spindle PSU) externally, its not in a case at the moment so its got a nice 230vAC going through it lol.. None of the wires are shielded so ive moved them out of the way until the new ones turn up.. This was causing errors like the z axis nudging slightly, it crashed the drill bit a couple of times (breaking them) and other problems were x and y axis nudging also..
This is the final setup (at least until i can mount them in cases)
Old Apr 14, 2012 | 10:11 AM
  #799
xxk1llaxx's Avatar
Duuude Sick Build!
Old Apr 14, 2012 | 07:24 PM
  #800
NA James's Avatar
How different is the newer crv rear to the older wagon rear
