FL 1998 Honda Civic EX-R ITR swap | track and mountain pass ready very nice build
Selling my 98 Civic Coupe. This car was put together with great attention to detail and buying only quality parts. Every bushing, suspension component, and most of the braking system is brand new. The engine is super healthy and the transmission shifts smooth. I use Pennzoil synthetic motor oil and Motul competition FF gear oil in the transmission. The engine hums when at idle and cruising. Its screams a smooth symphony at WOT. This car made 184whp on a dynojet on 93 octane no cool down time. (Link to dyno pull below) That's on a stock JDM P73 ecu. This thing will pick up some super nice power with a Hondata and a proper tune.
There are a few small cosmetic flaws. The rear bumper has a crack in it. The car was repainted. Its pretty decent, but has some imperfections. It is way better than most civics this age and waaayyy better than most cars this age which still have original paint. The headliner shows its age but isnt hanging down. The sunroof slider is missing its fabric cover. I had planned to do a sunroof delete but didnt get to it. There is nothing in the trunk and I removed the carpet in the car. That's really I can point off the top of my head. Very insignificant but I like to mention to be as forward as possible and give the potential buyer a good mental image of the car overall.
I drive the car a few times a week. Its drives great isnt to loud and quite tame just cruising. The car does have a race spec LSD in the transmission. Its not like the OEM LSD. Its does a much better job at distributing power to both wheel but when not under full load like turning at low speeds and barely on throttle it does click. You can both hear it and feel in. It is not subtle, you will know there is a proper race LSD in the transmission. You can learn to drive it to reduce how often it happens.
This car is very fun to drive. It handles and brakes absolutely amazing. It's hard to find well built civics for a fair price or find one period.
****The steering rack has been modified with an Integra pinion gear to reduce the amount of wheel input needed to turn the car.
****the car had power steering and AC with this swap. I removed it, but still have all the parts which will be included with the sale.
Drivetrain:
B18C Type R -3300
JDM P73 ECU
Type R transmission
ATS carbon LSD -1400
Insane axles -500
Toda rep headers and test pipe - 350
Kustom Tuned intake with heat shield - 300
AEM FPR - 120
B&M fuel pressure gauge -40
New Acura Type R Valve Cover -250
New HondaType R spark plug wires -80
New Honda Type R valve cover seals -60
New Honda Type R Distributor cap, rotor and seal -80
New NGK copper spark plugs -10
New NTK upstream O2 sensor -80
Valve lash set per Honda service manual
Larger aluminum radiator with distilled water and coolant additive -120
Stiffer engine mounts -250
Suspension:
Koni Yellow shocks - 480
Ground Control coilovers 500lb springs square -400
Extended top hats square -50
Megan extended lower ball joints -60
Skunk 2 upper arm ball joint -60
New front wheel hub bearings -100
ARP extended studs in the front -40
Energy suspension LCA bushings -40
New Honda rear LCA bushings -60
New sway bar end links - 60
New sway bar bushings - 25
New tie ends -90
VMS adjustable rear camber arms -60
New trailing arm bushings -80
New billet rear LCA -60
Wheels, Tire, Brakes:
Enkei RPF1 black 15x7 square -880
Bridgestone RE71R 205-50-15 square - 460
Wilwood 4 piston front calipers -500
Wilwood rotors and brake pads
Stainless braided brake lines square -90
Integra rear caliper setup - 150
EBC rear rotors and brake pads -140
Prospeed brake fluid -50
Interior:
Sparco leather steering wheel -220
Sparco wheel hub -100
NRG quick release -90
Fastline Shifter -220
New solid shifter bushings -30
Recaro rep front bucket seats with sliders -400
Civic Type R door panels -200
Red Type R style arm rest cover -20
All panels painted black
Carpet removed
The total of this parts list amounts to over $12,000 and that doesnt include the car. If you feel you have connections and wont pay retail, subtract 15% which is the avg a connect gets you. That amounts to over $10,000. And let's not forget, labor cost for install and setting up the car. That's thousands more.
I am selling at $8,500. Price is firm.
If you have any question feel free to ask. I respond quickly.
Drivetrain:
B18C Type R -3300
JDM P73 ECU
Type R transmission
Insane axles -500
AEM FPR - 120
Suspension:
New tie ends -90
Interior:
Carpet removed
Cort Astro
12-11-2013 04:45 PM
silenttones
Northern California (Sales)
19
12-15-2008 01:56 AM
