HELP!! Tranny problem.
Old Jun 1, 2009 | 05:59 PM
RobEK's Avatar
Default HELP!! Tranny problem.
hey, i got a jdm b16 cable tranny an i just bought it an just took it apart caz it was grinding 3rd gear...an i put it all back together an now the input shaft wont turn.! it turns when everything is lose....idk what the prob. is.... Someone help!!!
Old Jun 1, 2009 | 08:57 PM
stevenDAtegra's Avatar
Default Re: HELP!! Tranny problem.
Try moving the gear selector around starting in neutral and then try to spin it. When I put mine back together once this happened but after some gear changes, it all settled in
Old Jun 2, 2009 | 03:41 AM
RobEK's Avatar
ok, but everything spins when the case is off, but when i go back together an everything is tight it wont spin....
Old Jun 2, 2009 | 04:20 AM
Honda Bull's Avatar
You didn't put it back together correctly.
1) Is the c-clip sealed on the countershaft bearing?
2) Is the reverse gear upside down?
3) Is it somehow stuck in two gears at once?
They are just a few. Take it apart and keep looking aound to see something.
Old Jun 2, 2009 | 08:55 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
is it lubed up?
Old Jun 2, 2009 | 01:30 PM
RobEK's Avatar
The c-clip is good, the reverse gear is good, an it was in 2 gears wat once but i took it apart an fixed it....but still doesnt spin.
Old Jun 2, 2009 | 01:31 PM
RobEK's Avatar
Originally Posted by ohsnapzafingcu
is it lubed up?
No, it doesnt have to be..it will turn when theres no lube in it.
Old Jun 2, 2009 | 07:15 PM
Honda Bull's Avatar
is it lubed up?
LOL. Please tell me that's sarcasm...
RobEK, is the inputshaft locating tab (flat washer with a turn-down tab found under the input shaft bearing) facing down towards the bell housing? And is it in the right location to align with the top transmission case?
Old Jun 3, 2009 | 08:21 AM
RobEK's Avatar
i am gunna take it back apart an check again, thanks for the help.
beastsohc
Transmission & Drivetrain
Jan 18, 2009 05:08 AM
crxmex
Nov 4, 2007 01:33 AM
VTECcnIT
Feb 25, 2006 12:12 PM
LsBoy
Nov 12, 2003 09:05 PM
EF9
Dec 19, 2001 11:32 PM
