Having problems going into 1st gear!! ?
New User
the damn thing has happened to me for a while, I'm just too lazy and got used to it... but if anyone can figure out what the problem it might be, i'll be appreciated. well, it mostly happens in stop-go traffic, when I shift into 1st from neutral, it only goes half way in, just like the reverse gear problem, I have to release the clutch pedal a little bit so it goes in, or shift to other gears then I can shift into 1st. what problem it might be? My car is a 97.
Re: Having problems going into 1st gear!! ? (mike2016)
I always thought that you couldn't shift back into first if you're over 25 mph? Anyways..just double clutch. Works for me.
--Sam
--Sam
1 Post
Re: Having problems going into 1st gear!! ? (checkmate58)
--Sam
--Sam
(It will also go from 5th to 2nd at over 100mph...)
New User
Re: Having problems going into 1st gear!! ? (JG Luder)
yeah I have to force it into 1st from over 20mph.... but i can not even shift into 1st completely at FULL STOP... and grinds 2nd gear sometimes while normal driving...
