Transmission & Drivetrain Gearboxes, Differentials, Clutches
Cable B-Series transmission bearing
Old 03-28-2014, 02:29 PM
F22Master's Avatar
Default Cable B-Series transmission bearing
Well, I was trying to test fit my cases together after rebuilding my cable B16 trans, and the top mainshaft bearing got stuck in the upper case half. As I tried to get it out, it busted open, sending ball bearings everywhere....
Im having trouble finding this bearing alone, and for a decent price. The part number is 91004-PS1-003. Measurements are: 70mm OD, 22mm ID, 18mm thick. Most places have it listed as discontinued, but the the places that dont have it listed at around $60... Found it on ebay too, same price...
Does anyone know where I could get this bearing for cheaper? Or does anyone have a good used one lying around? Im pretty sure its the same bearing as the LS cable transmissions.
Thanks!
Old 03-28-2014, 09:06 PM
D Tranny Guru
Mista Bone's Avatar
Default Re: Cable B-Series transmission bearing
Why not reassemble the bearing after cleaning, then check mainshaft shimming?
Check with Dave or James at Synchrotech, forum sponsors here for a reason.
Next time use a space heater and the bearing will drop out with ease.
Old 03-29-2014, 04:37 AM
F22Master's Avatar
Ive been trying to reassemble but can't get it back together... any tips?
Already talking with synchrotech
And it was a bit of surface corrosion that got it stuck. Just took some 400 grit to the bearing bore and its all clean now, and three outer race slides in beautifully.
Old 03-29-2014, 06:11 PM
D Tranny Guru
Mista Bone's Avatar
It literally just snaps back together.
Old 03-29-2014, 06:16 PM
F22Master's Avatar
I don't know, I can't see any way to get it back together... how do you hold all the ***** and the cage? Do you insert it at a certain angle? I just don't see it.
Old 03-29-2014, 06:53 PM
F22Master's Avatar
Here is what I'm working with. Inner race, outer race, 12 *****, and the cage.
Old 03-31-2014, 12:23 PM
Aquafina's Avatar
I have an OE NTN bearing in stock.
Old 03-31-2014, 04:37 PM
F22Master's Avatar
Any tips on reassembling this thing? Im just not seeing how this thing "just snaps back together"...
Old 03-31-2014, 08:20 PM
D Tranny Guru
Mista Bone's Avatar
Note I was tearing the bearings apart to get the plastic out to recycle the scrap steel.
Old 03-31-2014, 08:57 PM
F22Master's Avatar
Right, races like that are pretty straight forward. Hell, they hold the damn ***** for you lol. No matter how much grease I use, or magnets, or tape, etc I use, I cant get the ***** to stay around the inner race... Maybe ill try hot glue, then melt it out after...
But thanks for the pics, it at least lets me know the theory.
ef-hatchcrap
05-14-2014 09:24 AM
Stillo
08-18-2008 08:00 PM
allnaturalb16
09-30-2006 10:03 AM
Wopsicle69
01-06-2005 04:44 PM
Quick Reply: Cable B-Series transmission bearing
